Bridges drill refurb- replacement chuck shaft
Home › Forums › Workshop Tools and Tooling › Bridges drill refurb- replacement chuck shaft
  • #235632
    John Rudd
      @johnrudd16576
      following on from my other thread, I may need to make a new shaft for the gearbox, the drill is a 2 speed job with a crash gearbox affair….
      The shaft that emerges from the gear box carries the chuck and runs at the front in a 6200 bearing, supported at the rear with a nr bearing. The shaft carries the spur gear for the 2 speeds….the spur gear has a pb bush in the midle so it rides up/down the shaft as required…
      So my question is what grade of steel is needed for a new shaft?
      I'm guessing EN1 is going to be too soft…?
      #18069
      John Rudd
        @johnrudd16576
        #235703
        John Rudd
          @johnrudd16576
          No recommendations on choice of material for this?
          #235707
          Speedy Builder5
            @speedybuilder5
            Silver steel – good for most things.
            BobH
            #235709
            Lambton
              @lambton
              John,
              Make it from a good, UK made if possible, HT bolt grade 12.9 (imperial grade V) if you can get one or even a standard 8.8 (imperial grade R or S) would be much better than EN1.
              HT bolts are good at resisting torque as well as high tensile loads.
              Eric
              #235716
              John Rudd
                @johnrudd16576
                Gents,
                Thanks for the replies, I had thought of SS, but maybe a but hard to machine?
                I had considered the bolt route too but was concerned over the grade…
                A happy bunny now, I'll go look for a bolt…smiley
                #235726
                Fatgadgi
                  @fatgadgi
                  Hi John
                  I would guess a medium carbon steel such as EN8 may have originally been used.
                  This is not bad to machine and you can get free maching grades as well
                  Cheers Will
