Bridge port spares
Bridge port spares
Home Forums Workshop Techniques Bridge port spares
  • #15505
    Tony Perks
      @tonyperks94676
      #64055
      Tony Perks
        @tonyperks94676
        Hi all new to the forum, I have a few machines that i use myself as I supply performance cylinders heads, for 4 stroke prtrol engines, I have a bidgeport vertical turret mill and need some spare parts namely the stol mechanism, for the horizonal feed as mine is missing so the machine will not stop when the feed is selected.
        So my question is wher can i get parts from I need the stops the brackets that hold the bar that runs along the bed that trips the stops, and the bar Many thanks in advance Tony P.
        #64104
          Well as no body else has answered as KWIL posted elsewher you can get parts from teh following
          J
          #64123
          KWIL
            @kwil
            Since this appears to be just the bar and trip stops, why not make what you need?
            #64131
            James B
              @jamesb
              Hi Tony,
              I’ve not tried myself, but I have been told you can source spares from the link below – they offer rebuilt Bridgeports…
              James
              #64199
              Tony Perks
                @tonyperks94676
                thanks hardinge seems to an american firm and I will check out the other later.
                #64215
                Weldsol
                  @weldsol
                  Hardinge are in the uk that is where I got my spares from
                  Paul
                  Hardinge Machine Tools, Ltd.
                  Whiteacres
                  Cambridge Road
                  Whetstone
                  Leicester
                  LE8 6BD England
                  Tel: +44 (0)116 2869900
                  Fax: +44 (0)116 2869901
                  e-mail:
                  [email protected]
                  web site: http://www.hardinge.co.uk
                  #85023
                  stevef53
                    @stevef53
                    Hi Tony,
                    You probably fixed this already, but if not try The engineers emporium (www.theengineersemporium.co.uk) as they are breaking bridgeports. I got bits from hardinge, but found them expensive.
                    cheers
                    Steve
