PV BAKER REPAIR
PV BAKER REPAIR
Home Forums Locomotives PV BAKER REPAIR
  • #1009
    peter allen 1
      @peterallen1
      ANY HINTS ON REMOVAL OF PETTYCOAT PIPE
      #68061
      peter allen 1
        @peterallen1
        I need to remove the pettycoat pipe to access and remove the blown superheater on PV Baker on a loco loaned to our club. The drawing shows it to be inserted into a brass casting but no means of fixing is shown. The pipe is copper the casting brass, there are no signs of solder or grub screws. I have made up a stepped drift to fit pipe but am reluctant to give more than a sharp tap with 1lb hammer this had no effect. The smoke stack casting is riveted to the smoke box but heads are not visible on inside. There is a copper reinforcing ring which appears to be integral with petticoat pipe covering up where rivet heads would be Any hints would be appreciated.
        #105840
        Ron Hancock
          @ronhancock63652
          Hi i also have a pv baker 3 1/2 gauge also strugling to finnish i have a set of A3 drawings but a lot is missing when it comes to building.
          I have to work out the plumbing and cheeses remake if you need a copy of drawings i can try and copy these.
          Love to know how your getting on with your engine.
          Ron
          #379567
          Paul McGee 1
            @paulmcgee1
            drawings though basic can be had from
            Drawings (6 sheets) Rolled in a tube
            Paul McGee
