WM250VF Loose Saddle
Home Forums Help and Assistance! (Offered or Wanted) WM250VF Loose Saddle
  • #33345
    John Slaven
      @johnslaven66698
      John Slaven
        @johnslaven66698
        Hi All,
        My WM250 seems to have a very loose saddle. I can see no obvious gib adjustments. Is there some other adjustment for the saddle that I have missed? Any help would be much appreciated.
        Cheers the noo
        John.
        #391324
        mechman48
          @mechman48
          I have a 250V-F too… this happened to me, have a look at the back of the saddle, under the shear, you should find a metal 'gib strip' held on by bolts these may well be loose, give them a snug up , it should fix the problem.
          George.
          #391326
          Howard Lewis
            @howardlewis46836
            If there are no obvious gib strip adjusters along the side, there may be a large screwdriver slotted item on the end, under the handwheel. This will drive a wedge onto the gib to take out slack. They do work loose and increase slack and so need resetting from time to time..
            #391328
            mechman48
              @mechman48
              Just had a look at my manual, the item I mentioned is part # 63 on the carriage assembly page.
              George.
              #391329
              John Slaven
                @johnslaven66698
                Hi George and Howard,
                Thanks for the reply. I'll have a look this afternoon. The saddle is pretty loose and parting off is near impossible.
                Cheers the noo
                John.
                #391343
                mechman48
                  @mechman48
                  Just on the off chance check the 4 SHSC that fasten the cross slide to the saddle gear box, they may have also worked loose enough to give it slight lift…?
                  George.
                  #391388
                  John Slaven
                    @johnslaven66698
                    Hi All,
                    Thanks for the replies. George, you were right. The 4 allen bolts at the back of the saddle were loose. Gave them a snug up and the saddle feels a lot better. I can now part with confidence!
                    Cheers the noo
                    John.
                    #391468
                    mechman48
                      @mechman48
                      thumbs up
                      Geo.
