Which Chuck?
Which Chuck?
Home Forums Workshop Tools and Tooling Which Chuck?
Viewing 25 posts - 1 through 25 (of 36 total)
  • #303644
    Lee Goulding
      @leegoulding74917
      Hi Guys
      Which would you go for out of these
      Thanks
      Lee Goulding
        @leegoulding74917
        #303645
        MW
          @mw27036
          Vertex one would probably suit my purposes.
          Michael W
          #303646
          Lee Goulding
            @leegoulding74917
            ok thanks for that any reason above the other you would choose that
            #303648
            mechman48
              @mechman48
              My choice would be…
              1. Pratt Burnerd…. reputation & quality… these days?
              2. Vertex… price.
              George.
              #303649
                I'd go Pratt, Tos, Vertex. Easier to get spares and extra jaws for the pratt now and in the future.
                J
                #303651
                Clive Foster
                  @clivefoster55965
                  Fair few years since I bought anything from Vertex but all the gear I have is of at least more than adequate workshop quality outright, not just good for the money, and some rather better. If they have maintained quality standards then the Vertex should be fine.
                  Put a smaller, 125 mm, TOS on a SouthBend 35 years or so back and that was very good indeed. Don't know about the ordinary Pratt Bernurd but the precision 160 mm I have is pretty much beyond reproach. In a similar position to you some 20-25 years back I figured that staying out of t'pub and beans on toast for a month with meant I could stretch to the P-B precision. Still had to team it with an economy, part machined D1-4 backplate from Chester but its worked out fine. May have been a touch lucky as Chester were more focused on price than outright quality in those days.
                  Slightly scary to note that prices in £ are near enough the same as I paid back when I got the P-B. Nice to see that the poor quality end of the market seems to have disappeared. In those day most of the real low end offerings were little better than a well used chuck of decent provenance yet still not really affordable to the impecunious.
                  Might be worth looking into the width of the jaw gripping faces. My P-B precision has narrower faces than usual with standard chucks. Reduces ultimate gripping power but nicer on small work, an advantage not to be distained when one chuck has to do everything. Got a Taylor if I really need to grab something! Seems that on precision and light duty chucks, both 3 and 4 jaw, the jaws taper down further than the standard versions ending up with gripping faces around the same width as those on the next size down chuck. For 160 mm and up chucks this starts to get noticeable. My ordinary 200 mm four jaw is significantly more cumbersome due to this than its light duty companion and, in consequence, is almost never used.
                  Clive.
                  #303652
                  Lee Goulding
                    @leegoulding74917
                    Thanks for all the replies and a real mixed bag and i'm leaning towards the Pratt due to reputation.
                    #303654
                      I'd go Vertex simply because it's the cheapest. Paying extra for unnecessary precision would dent my bank account and I never do that without reasonable cause.
                      Chris Evans 6
                        @chrisevans6
                        I recently bought a 160mm three jaw from ARC. the whole chuck was cheaper than new jaws for my existing Pratt Bunerd chuck. The new one (I think it is a Zither) runs very true but is an awful notchy stiff action in use.
                        #303657
                        Lee Goulding
                          @leegoulding74917
                          ok thanks for that guys
                          #303689
                          Nick_G
                            @nick_g
                            Any reason Bison is not listed.?
                            I have both Pratt and Bison chucks bought as new items. It pains me to say it as a 'Brit' but I personally prefer the Bison over the Pratt. sad
                            Also I thought that a 125mm chuck was the standard size on X10 series machines. – Depending upon what you are making bigger isn't always better.
                            Nick
                            #303692
                              Bison was over budget going by previous thread unless you can find them at the price we got ours at.
                              #303711
                              Lee Goulding
                                @leegoulding74917
                                I didn't list Bison I just thought those 3 as a comparison
                                #303713
                                Lee Goulding
                                  @leegoulding74917
                                  Hi Nick
                                  I'm only looking at 6" chucks as I was advised from the seller that a good 6" chuck would be good to replace the 5" that's on there and the chuckbthats on there doesn't have any internal Jaws and no makers stamp on it and the seller had tried different jaws to no avail
                                  The chuck that's on even after being stripped and regressed is still very stiff
                                  Thanks
                                  #303718
                                  David Standing 1
                                    @davidstanding1
                                    Posted by Nick_G on 22/06/2017 17:51:20:
                                    Nick
                                    Nick
                                    You are correct – 125mm is the standard chuck size for an X10.
                                    I'm greedy, so I got a 160mm for mine too teeth 2
                                    #303730
                                    Lee Goulding
                                      @leegoulding74917
                                      Hi David
                                      What 6" chuck do you have
                                      #303733
                                      David Standing 1
                                        @davidstanding1
                                        Posted by Lee Goulding on 22/06/2017 21:07:44:
                                        Hi David
                                        Lee – you are getting too OCD lol, too many posts/threads, your memory is going – don't you remember, the 160mm D1-3 Pratt Burnerd one I mentioned the other day in one of your other threads, I got it off eBay recently for just £98 posted wink 2
                                        #303736
                                        Lee Goulding
                                          @leegoulding74917
                                          Ah.. yes I do sorry pal got toads of stuff going on at the same time
                                          #303741
                                          David Standing 1
                                            @davidstanding1
                                            Posted by Lee Goulding on 22/06/2017 21:33:47:
                                            I know you have smile p.
                                            Slow down, take a deep breath, concentrate on one thing at a time, you'll achieve much more than doing an impression of a catherine wheel wink 2 .
                                            #303744
                                            Lee Goulding
                                              @leegoulding74917
                                              I Know.. good advice
                                              It's because I'm doing a full garage workshop at the same time and I'm now needing to get the lathe in place so I can finish the rest around it 👍
                                              #303815
                                              MW
                                                @mw27036
                                                Posted by Lee Goulding on 22/06/2017 12:32:03:
                                                Price point is very good, especially for vertex given their gear isn't really cheap, normally you can expect a high price. More or less always over £100 for a set of parallels or vise or chuck etc..
                                                My chuck is a standard HBM 5" 3 jaw, maybe sometimes it's just a case of the "lucky Winchester" (99% are useless and 1% are fantastic). But mine regularly holds a decently round bar to 0.02-0.03mm at chuck point, or 5mm out or so.
                                                I would consider Vertex to hold a better name than HBM, mainly because they normally give you anything you buy with an inspection certificate. (hand written as well, which slightly helps in the unlikely case of a refund required, because it means someone at least had to pass their eyes over it.)
                                                I would also say I speak from experience with vertex whereas I've never used pratt/Bernard or a TOS device, although I have seen TOS chucks on much bigger lathes.
                                                Michael W
                                                Edited By Michael-w on 23/06/2017 11:45:10
                                                #303817
                                                Lee Goulding
                                                  @leegoulding74917
                                                  ok thanks for that Michael
                                                  #303819
                                                  David Standing 1
                                                    @davidstanding1
                                                    Posted by Lee Goulding on 22/06/2017 22:17:24:
                                                    Exactly the same here.
                                                    Have you seen my new toy? wink 2.
                                                    Edited By David Standing 1 on 23/06/2017 11:47:20
                                                    #303828
                                                    Lee Goulding
                                                      @leegoulding74917
                                                      i actually emailed him about it but TBH i was worried about the size just wish i had bought the 280 from you as it nice and clean
