Where to start?
Where to start?
Home › Forums › Beginners questions › Where to start?
Viewing 16 posts - 26 through 41 (of 41 total)
  • #169749
    Michael Horner
      @michaelhorner54327
      This bit you have to read:
      I tried to bounce ideas and facts off my OH explaining all the above arguments etc. Her attitude was 'well how much is all this going to cost?'. I told her i was working on around a £6K budget overall and over time. Her answer?
      "Well make it £8K and don't mess about 'cos i want my bath".
      You lucky mansmiley
      #169760
      Gordon W
        @gordonw
        pjk- you have a tractor- have you got a rear loader or box, or can borrow one? Much easier and safer than swinging it off the loader.
        #169766
        pgk pgk
          @pgkpgk17461
          Posted by Gordon W on 16/11/2014 12:27:32:
          I understood most lathes are going to be top heavy? Sitting it in a link box might have it;s own issues.. and the reality fact that I'm 2m tall old f*rt with some back issues..so twisting in the cab to keep a rearwards lookout isn't so good. Skating it on the ground off the loader arms and taking my time would be better and keep total CoG low. Perhaps a few tyres as bumpers?
          #169803
          alan frost
            @alanfrost17805
            Very nice DSG on ebay at the moment which would do agri engineering and someone might get for £2K , less than a decent Myford (its a strange old world). Not suggesting for one moment its what you want and its not exactly even at £2K a bargain although it is at a guess well under a twentieth of its new price. I found a similar line a while back for a friend at I think about £400 (in Peterhead of all places-probably repaired fishing boats) but it does illustrate just what's available with patience.
            #169854
            Bob Unitt 1
              @bobunitt1
              If you've got a front-end loader on that tractor, you could suspend a fairly heavy machine from the loader-arms with lorry tie-downs, and counterbalance with a load of stone in the rear box (if you haven't got a proper rear weight).
              #169863
              Jon
                @jon
                Posted by pgk pgk on 15/11/2014 07:47:04:But to put it in practical terms: If one finds, say an M300 for £2K, then how extra much for shifting it and converting it to single phase (and some pocket money for extra muscle this end – it's not going to be a one-man job).
                what are the practical snags of a larger lathe?
                pgk
                Toughy, you could pull a fast one and run 240v single ph to 220v 3ph then have the hassle of rewiring the 'needed, controls. That s assuming the motors dual voltage, mine isn't.
                Otherwise plug and play from a 240v 1ph source now looking at £1300 for a 7.5kw inverter or same price for a noisy rotary convertor.
                Lifting and manouvering is a one man job. There is a tapped hole in front of spindle that you can screw in an eye bolt £3. Just pick it up with tractor. I use a 5ft crow bar to nudge across concrete floor purely because no room for a 6ft.
                Paid £850, sold Dickson toolpost £110 so cost £740. Trailer hire think was £36 and £3 for an eye bolt. Inverter £900 ex demo 3 1/2 years ago after a smaller 4kw £650 failing within 1 1/2hrs. Chucks and tooling £1000 should get you going, don't buy cheap chinese its wasted money.
                Downsides, if clothing catches you wont stop the machine. Chucks can be heavy certainly the 8", 6" Elliott no problem, one hand job with 5 1/4" easy with the D1-4 fitting.
                Serious positive is there are no change wheels to faff about with, something the Chinese haven't cottoned on to yet in near on 50 years. By that same with newer flat top Colchesters just dial in thread pitch whether metric or imperial think its up to 3.5mm pitch. I swore blind last Harrison scrapped 4 yrs ago I would never ever have another change wheel lathe again.
                Why not have a small Chinese and something along the lines of a Harrison M300.
                #169870
                Bob Brown 1
                  @bobbrown1
                  Jon, you contradicted your self !
                  "don't buy cheap Chinese its wasted money." then "Why not have a small Chinese and something along the lines of a Harrison M300" or is this lost in translation.
                  pgk
                  I hope your incoming power supply is up to the job as it is no good trying to run a lathe off an extension lead unless it's a small one.
                  Bob
                  #169891
                  pgk pgk
                    @pgkpgk17461
                    <<If you've got a front-end loader on that tractor, you could suspend a fairly heavy machine from the loader-arms with lorry tie-downs, and counterbalance with a load of stone in the rear box (if you haven't got a proper rear weight).>>
                    It's got ballasted rear tyres and taking the bucket off and using the bucket bar directly saves a good 200Kg and if necessary the topper or plough on the back would be a nice levered counterweight I suppose. Or possibly if it was on a pallet make up some skids for that and just drag it with the quadbike. I'm happier about the shifting now I;ve pondered that more.
                    <<I hope your incoming power supply is up to the job as it is no good trying to run a lathe off an extension lead unless it's a small one.>>
                    When sparkie wired up the shed I think he said I was good for 60amps – it's done correctly with it's own consumer unit so extra circuits shoudn't be an issue if needed. I was anal about making sure no insurance company could bitch in the event of a disaster – my r/c helis aren't cheap either.
                    <<Chester UK have an open week from the 1st–5th December,>>
                    I popped along today.. it's less than an hour away.. and had a long chat…food for thought .
                    Any comments about their 'crusader delux'?
                    #169893
                    magpie
                      @magpie
                      I think John (bogstandard2) has a crusader, perhaps he could give you some advice on that. I will have a word with him in case he does not see this post.
                      Cheers Derek.
                      #170043
                      pgk pgk
                        @pgkpgk17461
                        John,
                        That's a very kind offer which I obviously accept. Apart from chores around the farm which are usually flexible I'm almost always free just say when and a postcode…
                        pgk
                        #170046
                        robertj siddle
                          @robertjsiddle
                          Chinese lathes are used around the world successfully and accurately.
                          Could someone please inform the xenophobic "Don't buy 'owt unless its fifty years old and made in Britain/USA and used by tweed wearing pipe smoking old farts, that they are becoming boring. And they are just plain wrong.
                          It would be more helpful if these people used their skills and experience to help us newcomers use the technology available in this world rather than looking back to the golden days that never existed.
                          #170052
                          IanT
                            @iant
                            Well Robert – I am old (ish) and somewhat "windy" these days (well OK very windy) but I can assure you that I haven't worn tweed or smoked a pipe for well over 50 years – when they were required "accessories" for touring pubs on a Sunday in my mates MG A.
                            And I have never, ever touched a Xylophone either!!
                            IanT
                            PS Especially not a Chinese one!
                            Edited By IanT on 19/11/2014 12:31:21
                            #170070
                            magpie
                              @magpie
                              Nice one Robert ! I couldn't agree more.
                              Cheers Derek.
                              #170074
                              magpie
                                @magpie
                                Hi pgk, as John said, you are very welcome to pop over anytime, but please send me a PM beforehand as I spend a fair bit of time at "men in sheds" these days but if I know I am due a visit I will make sure I am home.
                                Cheers Derek.
                                #170098
                                Roger Williams 2
                                  @rogerwilliams2
                                  Robert, I agree with you when you state that its wrong to generalise on Chinese machinery, but is it not wrong also that you to generalise on 50 year old British/US stuff ?. To the OP, have a look at both, and buy what you fancy, and good luck.
                                  A friend of mine has owned a Warco 13/27 lathe for years, excellent bit of kit, another one to consider.Cheers.
                                  PS, nearly forgot, I own a lathe at least 53 years old, probably as good as anything else out there and Im not a boring old fart, although I do get the wind a bit, well a lot !!.  indecision
                                  Edited By Roger Williams 2 on 19/11/2014 21:03:08
                                  #170155
                                  robertj siddle
                                    @robertjsiddle
                                    Roger et al,
                                    My post was intended as rather tongue-in-cheek and there was no intention to offend anyone. Actually I sent it in error as I realised that one can only read the words and do not get to hear the music. But being an aged geriatric , it was in the ether before I could stop it.
                                    A huge amount of truly great work has been done on the older machines and I am in awe of the skills demonstrated by their users and I hope that those happy with their machinery continue to produce the goods.
                                    We must remember that these machines are not the only road to salvation.
                                    If we look around the model engineering community worldwide, not just in our local parish, we will see similar work standards being displayed on quote, "Cheap Chinese |Rubbish" , unquote.
                                    There are many roads to Rome. We should enjoy the diversity and appreciate the variety of experiences.
                                    After one really frustrating day at work when I was whingeing about the newer generation and their approach to life , my boss asked, " What would the world look like if we all thought and acted like you?"
                                    It doesn't bear thinking about.
