Where to buy dowel pins in small quantities
Home Forums General Questions Where to buy dowel pins in small quantities
  • #554695
    Hollowpoint
      @hollowpoint
      Hi guys
      Does anyone know where I can buy imperial sized hardened dowel pins in small quantities?
      I literally just need a couple of 7/32 dia by 5/8 long. I don't fancy buying a 100 @ £25. 😔
      Hollowpoint
        @hollowpoint
        #554697
        Paul M
          @paulm98238
          Try Accu.co.uk. I have purchased small quantities of dowel pins from them but not hardened. Worth a look.
          #554699
          not done it yet
            @notdoneityet
            Google is your friend? I found 2 companies selling these in small numbers in first 3 searches. One had a delivery charge of a fiver and I didn't look for your particular size but you might have to compromise on diameter. Might find 5.5mm easier than 7/32”?
            Edited By not done it yet on 19/07/2021 08:51:06
            #554703
            Hollowpoint
              @hollowpoint
              Posted by Paul M on 19/07/2021 08:41:25:
              I'll take a look. 🙂
              #554705
              Hollowpoint
                @hollowpoint
                Posted by not done it yet on 19/07/2021 08:50:26:
                I can't compromise on size unfortunately. What are the sites you found? I can only find the sizes I need at boneham. Minimum delivery is £7 which seems a lot for 2 pins.
                #554706
                Ian Skeldon 2
                  @ianskeldon2
                  Could you use drills cut and ground to length?
                  #554708
                  Hollowpoint
                    @hollowpoint
                    Posted by Ian Skeldon 2 on 19/07/2021 09:12:44:
                    Possibly a plan b. 🙂 Or make some out of silver steel perhaps.
                    #554709
                    John Hinkley
                      @johnhinkley26699
                      There is an advertiser on eBay who is offering 7/16" x 1" dowel pins at £2.05 for a pack of 5 with £2.20 additional postage, if you can reduce the length with a Dremel or similar?
                      7/16" dowel pin
                        Posted by John Hinkley on 19/07/2021 09:16:22:
                        They should be a nice tight fitwink
                        #554727
                        John Hinkley
                          @johnhinkley26699
                          Whoops! Should've gone to Specsavers!
                          I think my wife is right – I AM going do-lally.
                          Mark Barron
                            @markbarron78673
                            I've used Boneham's in the past with good results:
                            http://www.boneham.co,uk
                            #554825
                            David George 1
                              @davidgeorge1
                              Bonham and Turner is reliable supplier. Order on line and post or collect in person very helpfully if you need any help. Just had a look on line and they are 0.12p each
                              David
                              Edited By David George 1 on 19/07/2021 18:04:14
                              #554828
                              Ian Skeldon 2
                                @ianskeldon2
                                Posted by JasonB on 19/07/2021 10:04:23:
                                HAHA well spotted Jason, that made me smile.
                                #554829
                                Ian Skeldon 2
                                  @ianskeldon2
                                  Posted by John Hinkley on 19/07/2021 10:27:02:
                                  I didn't notice until Jason spotted it, I blame brexit laugh
                                  #554985
                                  JohnF
                                    @johnf59703
                                    I bought some last year from WDS components but not that size and it seems they don't have 7/32" they do however sell single units upwards.
                                    Have you considered using silver steel and harden it ? The problem is the tolerance may not suit you and there is a possibility of distortion after hardening however considering the short length its likely to be less of a problem ! All depends on the actual use.
                                    Edited By JohnF on 20/07/2021 23:06:05
                                    #555003
                                    Clive Foster
                                      @clivefoster55965
                                      Trouble with mail order of small quantities of inexpensive things is that you are basically paying for them being on the shelf and the work of picking, packing and posting. Not the things themselves.
                                      I guess £7 buys you about 10 minutes of person time plus p&p which isn't unreasonable for a firm that isn't highly organised for pick, pack'n post Amazon style.The work involved is pretty much the same for 2,000 as it is for 2. Just a bigger box.
                                      #555006
                                      Nick Wheeler
                                        @nickwheeler
                                        Posted by Clive Foster on 21/07/2021 09:42:35:
                                        That's exactly how it works.
                                        But how is the expense any different from driving to the next town to your 'local' supplier who will charge you £0.73 each for the three that you need? Your time isn't free either…
                                        #555008
                                        Mick B1
                                          @mickb1
                                          Posted by JohnF on 20/07/2021 23:05:13:
                                          I'd try that first before even considering purchase. Macc Models do 7/32, and all sizes I've had from them have been within a tenth or so. If you need them hard, probably best quench them endwise – but you might know that better than I do.
                                          #555009
                                          Circlip
                                            @circlip
                                            Delivery charge shouldn't be an excuse to inflate the price. This weeks purchases were both post free. One took 2 days, other overnight. First a D/G window locking mechanism, £6 saving over exactly the same item available less than ten miles away. Second, U/V activated glue, even on Flee, a price variation of up to £4.
                                            Had a couple of more than 1 hour trips recently to collect bits ( Thanks Windy, most enjoyable visit – was yaking for 3 1/2 hrs ), but was great to hear the car getting excited that it was going more than the Thursday "Chicken run" to the local supermarket.
                                            Regards Ian.
                                            Edit. Tail end of drills are not hardened.
                                            Edited By Circlip on 21/07/2021 10:58:05
