What tooling and collet should I get
Home › Forums › Beginners questions › What tooling and collet should I get
Viewing 25 posts - 1 through 25 (of 26 total)
  • #8633
    Julian taylor
      @juliantaylor20573
      #291098
      Julian taylor
        @juliantaylor20573
        Hi Guys
        First time poster here so hello
        I'm just about to buy a Warco WM12 mill to start building my own dive gear, mainly machining Delrin but also will be using aluminium. The types of things i will need to do are facing, removing material and cutting o-ring groves so it needs to be fairly close tolerances and neatly done.
        I just had a question about collets, collet chucks, tooling and associated stuff.
        Basically the question is whats the best way to go? Should I get a collet chuck and collets, an arbour so I can directly connect to the drawbar or another way. If I go collet chuck which tooling should I use.
        I think tools I would need would be
        – Endmills from 2 – 16 MM
        – Facemills
        – Groove cutters for perpendicular o-ring grooves (max 4mm wide).
        – Any other stuff too
        Any help and advice is greatly appreciated.
        Jools
        #291141
        John Reese
          @johnreese12848
          I would suggest an ER collet chuck capable of holding up to 16mm.
          Then get arbors for the size face mill you intend to use.
          Get a boring head to do the face grooving.
          Get a good quality drill chuck.
          Get a good quality copy of a Kurt vise.
          #291144
            Welcome Julian.
            +1 for ER collets. They will always win on maximum flexibility at reasonable cost.
            Julian taylor
              @juliantaylor20573
              Hi Guys
              Thanks for the input. Do you know, or can you suggest, which ER collet chuck I should get? All the other things I'll put on the list too.
              Cheers
              Jools
              #291149
              Julian taylor
                @juliantaylor20573
                Just looked and I think that ER25 looks to do the job.
                #291150
                bricky
                  @bricky
                  Hi Julian.
                  I would go for an ER32 or better still the ER40 because you will find in the future that you will want to use bigger tools or workpieces.
                  Frank
                  #291151
                  Julian taylor
                    @juliantaylor20573
                    Good advice, thanks Frank.
                    Could people list their reputable suppliers please.
                    #291157
                    Journeyman
                      @journeyman
                      Julian, the WM12 is a very small mill, ER 40 would be seriously oversize I think. I have the WM14 and I find ER25 adequate. I have used a 20mm endmill but it is definitely pushing the limits.
                        Cutting grooves for O rings sounds like you'll need a rotary table to fit the mill.
                        Julian taylor
                          @juliantaylor20573
                          Hi John
                          The max end mill a WM12 can take is 16mm anyway.
                          A larger one would would save me buying it again if I upgraded but as the new set would be an extra couple of hundred quid it wouldn't break the bank.
                          I suppose the downsides are that a larger collet may clash with work holding and clamps more.
                          Jools
                          #291160
                            If only using it for holding milling tools, anything bigger than ER25 is not really worth it, as I doubt you would ever want to hold a cutter with more than a 16mm shank in that mill. Larger faces mills etc. will normally fit directly into the spindle.
                            ER32 can be handy if you want to use it as an accurate woirkholder in the lathe.
                            Journeyman
                              @journeyman
                              It may be difficult to find ER40 with a 2MT shank the other drawback of large tooling is that it takes up precious headroom which is a problem on these small milling machines.
                              John Haine
                                @johnhaine32865
                                If it's available, buy one with an R8 taper and get R8 collets. That way you will get an additional 50mm or so of headroom as they don't project from the spindle more than a few mm. R8 collets grip like the proverbial, don't need to be furiously tightened, and are relatively cheap to buy.
                                #291242
                                mechman48
                                  @mechman48
                                  I would go for ER32 collet set; it will give you the facility to use a 20mm collet for that 'bit extra capacity'. if your machine has R8 spindle then go with R8 collet set.
                                  George.
                                  #291247
                                  Julian taylor
                                    @juliantaylor20573
                                    Hi George/John
                                    On the R8 collet the machine I am buying only has a 2mt option.
                                    In relation to the ER32 collet can I respectfully ask whether that would be required? The machine is limited to a 16mm end mill so there seems to be no need to have a bigger shank than cutting area IMHO.
                                    Julian
                                    #291248
                                    Martin Kyte
                                      @martinkyte99762
                                      Posted by Julian taylor on 29/03/2017 15:53:32:
                                      Jools
                                      That's brave of you. Isn't that a little 'mission critical'
                                      regards Martin
                                      #291249
                                      mechman48
                                        @mechman48
                                        You don't have to have he ER32 size, ER 25 will do what you need. I have the WM 16 – MT2 taper & on a couple of occasions I have used a 19mm insert type face mill to give me the option of completing the cut in one pass rather than two side by side passes… horses for courses I s'pose thinking
                                        George.
                                        #291251
                                        Julian taylor
                                          @juliantaylor20573
                                          regards Martin
                                          Yes and No I suppose. The equipment I'll be building, though it looks technical, is actually fairly basic in design and build.
                                          But yes it will be keeping me alive while over 60M underwater or while half a mile into an underwater cave system so yes very much mission critical
                                          Julian
                                          #291252
                                          Julian taylor
                                            @juliantaylor20573
                                            Posted by Martin Kyte on 30/03/2017 12:20:07:
                                            Jools
                                            regards Martin
                                            This type of stuff
                                            https://www.google.co.uk/search?q=rebreather+head+from+aluminium&espv=2&source=lnms&tbm=isch&sa=X&ved=0ahUKEwilkbTQkP7SAhVMDsAKHan2Dg4Q_AUIBygC&biw=1920&bih=994#tbm=isch&q=rebreather+head&*
                                            #291256
                                            Muzzer
                                              @muzzer
                                              Posted by Julian taylor on 30/03/2017 12:33:20:
                                              Jools
                                              regards Martin
                                              This type of stuff
                                              Dear god. That's not just mission critical, it's Darwinian?
                                              #291258
                                              John Stevenson 1
                                                @johnstevenson1
                                                Can't you just hold your breath for a bit ? wink
                                                #291262
                                                Julian taylor
                                                  @juliantaylor20573
                                                  Posted by John Stevenson on 30/03/2017 12:41:41:
                                                  Yes I can. Just not long enough to swim a mile laugh
                                                  #291281
                                                  richardandtracy
                                                    @richardandtracy
                                                    I have ER32 collets which I use on my lathe & milling head. I've ended up getting collet chucks with MT2, MT3 & MT4 ends so I can use the lot in my rotary table & drill press (MT2), lathe tailstock/milling head (MT3) and lathe headstock (MT4). Have a range from 6-20mm, bought one at a time when I needed them. On the mill, lathe tailstock & drill press I use the thing for tool holding, but every where else I use them for work holding. This is especially useful in the rotary table and on my little CNC where I have a Stevenson hexagonal collet chuck, to which I filed a number of slots so it could be clamped collet axis vertical.
                                                    So, don't get hung up on the fact the mill can only end mill 16mm diameter. There are many other uses for the same collets.
                                                    Having said that, you could go ER25 and if you need something bigger, get another collet chuck of the ER32 size. Get them direct from China/Hong Kong via E-bay & perfectly good ones are under £20.
                                                    Richard
                                                    #291287
                                                    Vic
                                                      @vic
                                                      For my mill and lathes I've settled on ER32 as there seem to be more fixtures and fitting that take this size than any other.
