What to buy next??
What to buy next??
Home › Forums › Beginners questions › What to buy next??
Viewing 25 posts - 1 through 25 (of 29 total)
  • #291104
    Curtis Rutter
      @curtisrutter61973
      So I got very little in the way of tooling with my lathe (myford ML7) when I purchased it and was wondering what would be the best piece of equipment to buy next?
      All I have at the moment is a 3 jaw Pratt & Burnerd chuck, Quick change toolpost with tangential toolholder and a bench grinder.
      My first thoughts are either a collet set or some tailstock tooling but if anyone has some better suggestions for me to spend some of my money then let me know!
      #8634
      Curtis Rutter
        @curtisrutter61973
        #291105
        not done it yet
          @notdoneityet
          Some HSS for the tangential toolholder?
          #291106
          Curtis Rutter
            @curtisrutter61973
            Have got some hss too 😊
            Edited By Curtis Rutter on 29/03/2017 17:07:44
            #291108
            Brian Oldford
              @brianoldford70365
              Four jaw chuck and the know-how to use it properly.
              #291109
              peak4
                @peak4
                I'm hardly the most experienced person on here, though I've been using my Myford on and off for 20+ years; not for model making, but general repairs, self generated workshop tool making, and car/bike parts.
                It depends on what you plan to use yours for, and also your budget, but I couldn't do without a 4 jaw independent chuck.
                Mainly though enjoy learning about your new toy.
                Bill
                #291110
                Roderick Jenkins
                  @roderickjenkins93242
                  I couldn't survive without a 4 jaw independent chuck and a dial test indicator.
                  Cheers,
                  Rod
                  #291111
                  Thor 🇳🇴
                    @thor
                    Well Curtis, the second item I got for my lathe decades ago was a 4-jaw independent, same when I bought a new lathe.
                    Thor
                    #291115
                    JA
                      @ja
                      Curtis
                      Four jaw independent chuck and a "clock" (d.t.i.).
                      When I bought my reconditioned S7 from Myford I opted for a four jaw chuck instead of the usual 3 jaw. They seemed a bit surprised.
                      JA
                      #291116
                      mick70
                        @mick70
                        as others say a 4 jaw
                        #291117
                        ianj
                          @ians
                          Tailstock drill chuck
                          #291118
                            After a tailstock chuck and a 4-jaw, buy stuff as you need it, rather than just in case.
                            That's the way to make your budget last!
                            old Al
                              @oldal
                              I have just taken delivery of a ME workshop crammed full of stuff that will be useful some time thats still in its wrappers.
                              A real shame, but he enjoyed buying it at the time.
                              4 jaw independant and a dti every time. Buy as you need, most things are available within 2 days.
                              Hope you have safety glasses!
                              #291124
                              Curtis Rutter
                                @curtisrutter61973
                                Cheers all, will begin the hunt for a 4 jaw and DTI, Know I'm going to need a drill chuck pretty soon too.
                                #291127
                                Clive Foster
                                  @clivefoster55965
                                  Spoilsport. Buying just in case means lots of cool toys to look at and the pleasure of smiling sweetly whilst saying "I told you I'd need it" about something you bought 30 odd years ago. Actually I think my record is approaching 36 years. But I'm working on it.
                                  One advantage of spending all your money on toys is that there is none left to buy materials so you can actually do something. Means you don't get shouted at for tracking swarf though the house.
                                  Seriously. Pick your first job and get the extra gubbins you need to do it. After careful consideration of what else said gubbins might be needed for so you buy the most appropriate size, quality and performance at a price you can afford. In particular with carbide tips available relatively inexpensively if you pick the right suppliers and types. I find it very arguable that you can get away without HSS and grinding facilities. Good grinders aren't cheap so setting up to grind and laying in a stock of HSS may well approach the cost of a lifetime supply of carbide for a light to moderate user.
                                  Clive.
                                  Edited By Clive Foster on 29/03/2017 18:00:05
                                  #291135
                                  mechman48
                                    @mechman48
                                    4 jaw independent chuck, tailstock drill chuck, DTI, 3 or 4" digi callipers for general use, then buy as you need.
                                    George.
                                    #291138
                                    Rik Shaw
                                      @rikshaw
                                      Basic extras with a new lathe would usually include the four jaw chuck as mentioned plus a fixed steady, a travelling steady and a faceplate. In addition you will probably soon find the need for a tailstock drill chuck and both a fixed and live tailstock centre. But (and pause for breath), the best way is to start your first job and just buy what you need to get it done. Ditto for all subsequent jobs. Eventually, you might have a new problem to contend with – where do I put it all? I am still trying to work that one out!
                                      Rik
                                      #291140
                                      Nigel McBurney 1
                                        @nigelmcburney1
                                        Bench grinder first,suggest 6 inch wheels,apart from hss tools ,there is a need to sharpen drills,and useful for sharpening other tools ,I made my first grinder 50 years ago before the days of cheap foreign tools. then tailstock drill chuck and a centre drill,then 4 jaw chuck. Then probably 2off 2 morse taper centres for turning work between centres. Then some means of accurate measurement ,digital calliper and a dial test indicator, then you can get on and do some reasonable turning,
                                        #291143
                                        duncan webster 1
                                          @duncanwebster1
                                          If you want to work to thous, don't rely on digi calipers, buy a micrometer
                                          #291178
                                          John Haine
                                            @johnhaine32865
                                            I got a faceplate and fixed steady with my S7, have used each precisely once in over 10 years. Buy when & if you need them.
                                            4J and DTI essential, also a good tailstock drill chuck.
                                            Make or buy a couple of boring bars.
                                            Digital caliper and/or micrometer(s) – I often use both on the same thing!
                                            Then you're pretty well set to do most jobs.
                                            Headstock collets are nice to have when you need them.
                                            #291182
                                            David Standing 1
                                              @davidstanding1
                                              Posted by duncan webster on 29/03/2017 19:46:51:
                                              Or just get some decent digital calipers wink 2.
                                              #291186
                                              ChrisH
                                                @chrish
                                                i would go on all that has been listed so far, starting with the 4 jaw independent chuck, the DTI and the 0-1" (or 0-25mm) micrometer – they are a 'must'.  The 4 jaw is my chuck of choice every time.
                                                If you have the space and money, a tool high on my list is the metal cutting bandsaw. I have a small one that fits under the bench but can still cut as per the usual 6×4's. Unless you really like hacksawing and are very good at it, meaning quick and able to cut straight every time, no wandering off line, the bandsaw is worth it''s weight in gold – certainly has been in my shed! Be lost without it now!
                                                Chris
                                                Edited By ChrisH on 29/03/2017 22:52:37
                                                #291202
                                                Curtis Rutter
                                                  @curtisrutter61973
                                                  Do you have a link to your band saw?
                                                  #291206
                                                  Ady1
                                                    @ady1
                                                    A tailstock chuck, a 4-jaw, a DTI and a micrometer
                                                    3 of the 4 can be had for about a tenner from a well known site to get you going
                                                    #291207
                                                    Tractor man
                                                      @tractorman
                                                      My wife would like me to pose the question “when do you stop buying” lol
                                                      As previous posters have mentioned- buy it when you need it. Otherwise you’ll end up like me with shelves full of stuff you may never use.
