What machine tools are these?
Home Forums Manual machine tools What machine tools are these?
Viewing 25 posts - 1 through 25 (of 31 total)
  • #14153
    Lindsay Sillars
      @lindsaysillars10659
      Lindsay Sillars
        img_3350.jpgimg_3349.jpgf064a7d8-d7c2-45f5-9cef-8069f6902701.jpg8616e172-c45a-48db-9497-0769023a026e.jpgAny information that anyone has on what these machine tools are.. make/models would be very much appreciated.
        Thank you
        #523155
        Oily Rag
          @oilyrag
          Third picture down is a BSA Tools Coventry die head grinder, for sharpening the 4 dies. The box next to it is the adaptor for the different die lead angles.
          The top two photos are of a compound angle rotary table, probably with a 60 hole indexing pin in the back. Possibly manufactured by Elliot.
          The bottom two photos show a compound grinding table but missing the top table section. Looks to be either Cincinnati, Taylor Hobson or more likely Jones & Shipman. The angle retainer bolt holes make it definitely likely to be a grinder attachment.
          Lots of dust in that workshop – but at least the rust bug has been kept at bay.
          Nice hammer head in the second photo background!
          Martin
          Edited By Oily Rag on 27/01/2021 22:32:28
          #523159
          Lindsay Sillars
            Hi Martin,
            Thanks so much for all of your information that will help us greatly on our endless google search that we have been on!
            Thankfully those pieces have been brought out of storage and have only been in the dusty shed for a short period of time.
            I didn't even notice that! the place is full of random metal objects collected over a long period of time!
            Again many thanks!
            Lindsay
            #523161
            Oily Rag
              @oilyrag
              Pleasure Lindsay,
              I'm sure someone will give you better details on the last item (the grinder attachment).
              I couldn't help but notice the second photo down shows a Coventry 3 jaw scroll chuck with serrated top jaws (Middle on right hand side). Does this have "Alfred Herbert Ltd., Coventry, Maker" stamped on it? Looks to be in fine condition and a real find if it is a genuine Herbert make.
              Martin
              #523166
              Lindsay Sillars
                It is in my dads tool storage I will give him a message and get him to check for me tomorrow.
                Amazing what you can find when a storage container is emptied after many years of being locked up!
                #523172
                Bazyle
                  @bazyle
                  Is the orange paint original? Only ever seen plant machinery that hideous. It might be an engraver's rotary indexer if not a grinder part as too light for machining.
                  The hammer head is a plannishing hammer.
                  #523173
                  Nigel Graham 2
                    @nigelgraham2
                    My word – Aladdin's Cave!
                    First off – the orange assembly – I suggest is a 2-axis direct-indexing table for use on a drilling-machine. I am not sure it would be sturdy enough for heavy milling. The handle simply lock the table but the associated metalwork looks complicated enough for it to have operated an indexing-feed.
                    The four larger holes in the face-plate appear owner-drilled for a specific work-piece or jig, suggesting a career in a batch-production or single-product machine-shop. The smaller holes seem more random but don't look like carelessness so might have had a similar purpose.
                    The little oops! on that innermost ring, and the broken T-slot edge, make me think them isolated accidents in a machine-shop that generally used its equipment properly and carefully. (A lot more carefully than I have seen…) That colour is unusual for machine-shop equipment, so possibly owner-applied, maybe as a form of asset code.
                    Not part of a wood-working machine, perhaps?
                    I'd guess the BSA-made item is part of a tool-&-cutter grinder – I assume the box next to it holds something related and is not just co-incidence. BSA was a major British manufacturer of motorcycles and tools, but started in armaments – British Small Arms – hence the rifles trade-mark on the box.
                    I'd say the assembly in the last two photos is from some sort of jig-borer.
                    The entire upper works seems adjustable through a small angle for level. Is it an optical illusion or are the mounting-lugs actually at an angle from the vertical?
                    The rotary function has what look like angle-stops. The left-right slide has a relatively massive, but micrometer-adjustment, travel-stop. I am puzzled why its slide-ways are offset from the rest of the device.
                    The top-slide's hefty dove-tails suggests it took the brunt of the moving for whatever the thing did, but I can't think what the projecting stud was for. It seems an odd place for it.
                    Whatever it is, exudes very high precision work!
                    #523177
                    Mark Easingwood
                      @markeasingwood33578
                      Hello,
                      The item I have circled looks like a "cap iron" from a plane, (woodwork), probably a very well made plane, as used in cabinet/furniture making. If you find the plane, and it's by a good maker, it may be worth a few bob.
                      #523183
                      Pete.
                        @pete-2
                        The orange thing looks very similar to a Taylor Hobson indexing table I have from an engraving machine, if you have a look on it there's probably a tag with info if you scrape some of that orange paint off.
                        #523206
                        larry phelan 1
                          @larryphelan1
                          Never know what you might find when you start digging !
                          #523212
                          Tim Stevens
                            @timstevens64731
                            Just for the record – BSA was the BIRMINGHAM Small Arms company. I know – I worked there in the mid 1960s.
                            Cheers, Tim
                            Edited By Tim Stevens on 28/01/2021 10:09:14
                            #523216
                            Eric Cox
                              @ericcox50497
                              The hammer in the background is a planishing hammer. I can remember using one in the school metal work class to decorate a copper serviette ring.
                              #523222
                              Bo’sun
                                @bosun58570
                                Another vote for planishing hammer. 8 kids (or thereabouts) and planishing hammers at school made for one hell of a racket. No ear defenders in those days. "What was that you said".
                                #523226
                                Anonymous
                                  I'd be interested to see more pictures of the BSA item. It doesn't look like any Coventry die grinder I've seen, but I didn't realise that anyone other than Herbert made grinding fixtures for Coventry dies.
                                  #523235
                                  Rex Hanman
                                    @rexhanman57403
                                    Posted by Bo'sun on 28/01/2021 10:48:55:
                                    Only8?? I had 20! Pardon?
                                    #523236
                                    Anthony Kendall
                                      @anthonykendall53479
                                      Posted by Tim Stevens on 28/01/2021 10:08:54:
                                      Cheers, Tim
                                      You probably helped make my bike.
                                      #523252
                                      Nigel Graham 2
                                        @nigelgraham2
                                        Pete – That's a thought. At first I could not determine its size but now see that the box below it is labelled for a 5-inch 3-jaw chuck. So it's not very big. Also the little "oops" circle was made by a milling-cutter or broad engraving-cutter (D-bit form), not a drill point.
                                        If by Taylor-Hobson the initials at least might be embossed on the casting, though not visible in those photos.
                                        If so, it could be RTH (Rank-Taylor-Hobson) or perhaps more likely as the accessory looks an old pattern, TTH (Taylor, Taylor Hobson.)
                                        I have operated an R-T-H engraving machine but the indexing-head for that was more like the ones advertised by ARC, etc., and I think with a single axis. It might not have been an RTH product. I now own a T-T.H. model, needing some work for re-use.
                                        Thank you Tim for the correction. My apologies to Birmingham – and yes I do know that despite widespread belief, Birmingham is one of a cluster of towns!
                                        Andrew – I didn't think the BSA fitting is for grinding die-chasers either, but could be for holding milling-cutters or boring-bar bits for sharpening their ends. My reason is that I have a die-grinding holder, made by Alfred Herbert, and it is holds the 4 chasers in the correct order in a row for use on a surface-grinder. However, I do concede other ways to the same end, e.g. on a conventional tool-&-cutter grinder, may have been made!
                                        There is another mystery object in the second photo – the bronze-looking thing standing on an angle-box to the left of the indexing attachment.
                                        #523256
                                        Pete Rimmer
                                          @peterimmer30576
                                          The orange device looks like a compound rapid indexer. Pull the lever and you can turn the table one notch to index again. There may be several slotted or drilled plates nearby where it was stored, to swap out for different indexing options.
                                          #523268
                                          noel shelley
                                            @noelshelley55608
                                            The BSA item does not look like a coventry die head chaser grinding fixture, either early or late type. Albert herbert were the main maker but clarkson also made them – I have one. Noel.
                                            #523293
                                            Vic
                                              @vic
                                              It’s all rubbish. Just send it all to me and I’ll arrange humane disposal. face 23
                                              #523368
                                              Lindsay Sillars
                                                Wow! thank you all so much for your response this is a great help!
                                                Nigel – Its beginning to feel like Narnia! you are indeed correct the box in the BSA picture is another attachment for the tool.
                                                For the last few pictures the mounting lugs do sit on an angle not just my bad photography ha!
                                                I will go on the search for any engraving in the casting and see if I can come across anything.
                                                The mystery object is part of a selection of parts that we have came across from Ornamental Turning lathes… another research hole that we are currently in.
                                                Mark – thank you for pointing that piece out. We will have a look to see if we can find the plane to go along with it and post any pictures we find.
                                                Andrew J – I'll pop another few pictures below of the BSA item.
                                                #523372
                                                Oily Rag
                                                  @oilyrag
                                                  Andrew, Nigel,
                                                  The BSA grinding fixture is shown with, what I believe to be, a boring tip sub fixture. I would be interested to see what the boxed attachment is next to the base tool.
                                                  Just as a Snap!
                                                  This my unit and there are 3 sub fixtures used with it, one is the boring bar tip grinder, one is a 'nest' for the re-grinding of Coventry dies (top rake) and one is a die lead angle grinder attachment. They all fit into the front slot, and are made with a fixed angle for top rake or lead accordingly.
                                                  Don't forget that following the DTI 'White Heat of Technology' programme instigated under Tony Wedgewood Benn around 1967 that Herberts' became 'Herbert BSA' group as the UK MTI was forced into mergers to establish a stronger scale of manufacturing and purchasing efficiency. Churchill Grinders of Altringham were also subsumed at a later date. Who can forget that sickly Magenta corporate colour of the 'new generation' Herbert BSA' group?
                                                  Meanwhile, whilst all this was happening, we at the Edgwick plant were developing the worlds first truly CNC machining centres and lathes – The Batchmatic 75 – 250, launched in 1972 but development units were in production environment with Rolls Royce at Derby, Associated Engineering at Ringwood, and at the BSA Armoury Road plant from 1969ish. These machines were a sea change to the former products, no cast iron beds weathered for 2 years anymore but fabricated from rolled steel and – shock, horror! welded – just like those pesky Japanese machine tools that wore out in 3 to 4 years!
                                                  Enough of history though, the tool in question was a universal tool grinder for many 'application specific' uses not covered by normal grinding fixtures, probably a little more 'useful' than the Herbert die head only unit.
                                                  Martin
                                                  #523376
                                                  Jss
                                                    @jss
                                                    I've got one of these too. It looks like a NAMCO thread chaser grinding fixture. I bought mine thinking I repurpose into something useful. At the moment it's a doorstop. Sorry the picture isn't too clear, but the photo in the bottom right shows it being used.
                                                    #523386
                                                    JDEng
                                                      @jdeng
                                                      The blue grey item in the last couple of photographs is the main part of a Jones & Shipman X9 radius grinding attachment. This is designed to fit the J&S 310 or 310T tool and cutter grinder and is used to grind radii onto milling cutters. As supplied it comes with numerous fittings to allow the cutters to be mounted and set-up, these are not present in the photographs.
