What is the thread on a bulkhead mounted RCA/Phono socket ?
Home › Forums › General Questions › What is the thread on a bulkhead mounted RCA/Phono socket ?
  • #258346
    Alan Wood 4
      @alanwood4
      It is close to 6mm / 0.25" and is not M6 fine or coarse but somewhere between these two. Doesn't appear to be UNF or BSF or BA. All engineering drawings found on the net so far do not specify what the thread is.
      For something so common in the AV world there must be a standard ?
      #24772
      Alan Wood 4
        @alanwood4
        #258348
        Brian Oldford
          @brianoldford70365
          Ah! Standards. You can have as many as you want.
          #258349
          Brian Oldford
            @brianoldford70365
            Joking apart; could it be one of the early sub 1/4" US threads shown here? https://sizes.com/tools/thread_american.htm
            #258352
            Ed Duffner
              @edduffner79357
              Hi Alan, do you mean the guitar type or the Hifi type? One is phono, the other is RCA. Can you upload a photo?
              Ed.
              #258354
              Sandgrounder
                @sandgrounder
                A quick look on the RS Comps' website and they are shown as 1/4" – 36 NUEF, which I am assuming means National Unified Extra Fine?
                Jeff Dayman
                  @jeffdayman43397
                  Thread 1/4"-36 UNEF is commonly used on many telecom and RF connectors even now. NUEF is probably a typo – UNEF stands for unified national extra fine. JD
                  #258360
                  john swift 1
                    @johnswift1
                    it looks like every one has their own standard
                    a  chassis mounting  phono socket with a    1/4"- 28  thread  from Farnell
                    http://www.farnell.com/datasheets/1944140.pdf
                    or  chassis mounting phono sockets   with  a 1/4" – 32   thread from Farnell
                    http://www.farnell.com/datasheets/1910868.pdf?_ga=1.63790508.2096815931.1475088858
                    http://www.farnell.com/cad/28985.pdf?_ga=1.62698287.2096815931.1475088858
                    Edited By john swift 1 on 28/09/2016 20:14:17
                    #258393
                    Geoff Theasby
                      @geofftheasby
                      May I suggest a very useful standard? Don't use RCA/Phono connectors!
                      Geoff
                      #258403
                      Alan Wood 4
                        @alanwood4
                        Thanks everyone, much appreciated. My project can proceed.
