What is normal quill play?
Home › Forums › General Questions › What is normal quill play?
Viewing 25 posts - 1 through 25 (of 28 total)
  • #162813
    alan w
      @alanw
      We have a Sieg X2 super mill and we're milling dreadful crooked lines in aluminium and wondering why. We can mill straight edges but not plunged slots. There is deviation of more than a millimeter from a straight line using a 6mm mill.
      We noticed that – with a DTI on the quill sleeve, we can pull and push the quill to reveal a 0.1mm play. Is this normal? If not, do we need to replace the bearings?
      If this is not the problem, any thoughts would be very welcome.
      Alan
      #23486
      alan w
        @alanw
        #162814
        Bob Brown 1
          @bobbrown1
          Not sure of the play in the Sieg but if you lock the quill that should help.
          Slots have a habit of pulling the cutter to one side depending on direction of travel, I remove the major part of the material in a slot with a smaller cutter and then machine the sides separately to final dimension with the same cutter.
          Bob
          #162819
            Can you give a bit more info such as
            Depth of cut on each pass, speed of feed and rpm, any cutting fluid?
            2, 3 or 4 flute cutter and make? sharp?
            Is the quill locked, is the axis that is not moving locked?
            My X3 did need the quill bearing preload adjusted as the nut was actually loose on arrivalbut not needed touching again in over siz years
            J
            #162822
            Russell Eberhardt
              @russelleberhardt48058
              The SX2 doesn't have a quill as such so there is nothing there to lock.
              Things to look at:
              Try to determine whether there is any movement in the spindle or the head itself. If the former check that the spindle nut is done up to the correct torque (there is a grub screw locking it). If it is the head itself try tightening the gib strip screws a little until the play disappears.
              Russell.
              #162823
              Sub Mandrel
                @submandrel
                Quill play is seen as rather unusual by most people, but it is perfectly acceptable behaviour for two consenting adults – just don't bring it up at a dinner party unless you know your hosts very well indeed.
                Aunty Stub.
                #162824
                  It sounds like the preload adjustment has gone slack. Take off the motor mounting plate to get at the end of the spindle. There's a locking grub screw in the ring, loosen it a couple of turns and nip up the ring until all play disappears but bearing does not bind. Retighten grub screw. Its a left-hand-thread BTW.
                  alan w
                    @alanw
                    Folks, thank you for your time in replying.
                    Bob, we're locking everything possible. But in case it's relevant, when the tool is "touching on" we notice that, if we lock the vertical axis, the note of the tool on the ork changes dramatically. Presumably, the locknig action is moving the quill. The gybs are all tight. Is this normal?
                    The two pass technique you mention may give us an accceptable fallback position – so thatnks for that thought.
                    Jason, sorry for missing out basic info, forcing you to ask for it. The depth of cut is 7mm, speed of feed – manual – is what felt right, but I would guess one turn of the handle every minute. We decided to try one-pass because repeatability is so bad that multiple passes leave the grand canyon effect.
                    We used some WD40 for some of the cut and nothing for others – there didn't seem to be any difference.
                    The tool look cross-like from the bottom – so 4 flute, I guess. Don't know the make – EBay second hand – no makers marks.
                    It looks shart – no obvious damage to the tip, no horrible noises or wild vibrations.
                    Not sure if we have a preload adjustment, but I'll look into it next Saturday. Thanks – any further thoughts appreciated.
                    Russell, I thought the quill was the thing holding the tool which we move up and down. It's got one of those ) so I assume we don't know what "quill" means. We put a DTI on the highest thing which rotates but isn't the tool holder on the removable morse taper which. That is where we found the 0.1mm play. You can hear it knock ad you yank the thing forwards and back. The gybs are tight, and this movement is present when the head is locked, so I don't think it's the head.
                    Stub. Thanks for those valuable insights. We are pretty broadminded, and each to their own (or preferably someone else's – all consenting) but when a quill strays too far – well it has to stop. We'd like our quill to return to the straight and narrow – to "straighten up and cut right" – as it were. But rest assured, the rotary club will remain ignorant of our shedular exploits.
                    Neil, "pre-load adjustment" – I'll read about that, thank you. We stripped it down as far as the motor mounting plate you mention yesterday – before accepting that this was a journey we were making without knownig what we were doing, but we'll find the grub screw and do as you suggest.
                    So thanks again all, for your time in making your comments.
                    Alan
                    #162950
                    Russell Eberhardt
                      A "quill" moves up and down in the head like in most drilling machines. The SX2 (well mine at least) has the spindle rotating in the head but fixed in the up and down direction. The whole head is moved up and down to put the cut on.
                      On top of the spindle you will find a nut or locking ring which is held in place by a grub screw. Slacken the grub screw and tighten the nut until the play disappears but not too tiight to stiffen the rotation. There is a correct tightening torque to give the right degree of pre-load but I just did it by feel.
                      Russell.
                      #162951
                        Even on a big solid mill 7mm is too great a depth of cut for a full width cut with a 6mm mill, even in aluminium. The sideways force pulling the cutter off line will be very high.
                        It's probably the toolbit bending, and the forces generated by this may have loosened the spindle bearings or headstock gibs. Try a 2mm DOC and make sure the table gibs are snug too.
                        Tony Pratt 1
                          @tonypratt1
                          If you are trying to cut a decent 6mm slot you need to rough out with something smaller i.e. 5mm, 3/16" or best of all 7/32", the idea is to leave minimal metal for the finishing cut. Use a sharp 6mm cutter to finish and a slow feed rate.
                          Tony
                          #162956
                            7mm is way too deep causing you to have to feed very slowly. Try about 1/5 to 1/4 of that and feed faster.
                            A 4 flute cutter is not ideal for slots as there is a tendancy for the cutter to move sideways, Ideally you want a 2-flute cutter often known as a slot drill for obvious reasons.
                            J
                            #162962
                            Nigel McBurney 1
                              @nigelmcburney1
                              Your original post stated that you were using plunge cuts ,you must never plunge cut with a 4 flute end mill,a two flute slot drill must be used, you also state that the slot wanders by one mm so even if there is 0.1 mm play in the bearings it should not produce an error of one mm, the cutter is probably blunt which does not help. On a small mill start with a 5 mm slot drill three cuts to achieve depth,then use 6mm slot drill to finish in one cut, lubricant ,soluble oil,or kerosene,or if the aluminium is bar i.e. he 20 or he 30 it can be cut dry,alloy plate is always best cut with lubricant,suggest you find someone who is a bit more experienced and get some instruction, when starting out in model engineering it is far easier to achieve good results on a small lathe,small mills never perform as well ,a mill needs a lot of weight and well supported spindle ,unlike a lathe if you want a 6mm slot ,you use the same cutter in a small hobby mill or a 1 1/2 tonne turret mill and the larger machine will give a better job.
                              #162965
                                Posted by Nigel McBurney 1 on 07/09/2014 20:17:26:
                                … you must never plunge cut with a 4 flute end mill,a two flute slot drill must be used …
                                Nigel,
                                I agree with most of what you said; but must just mention that there is a useful integer between two and four
                                Three flute cutters are very versatile.
                                Bob Brown 1
                                  @bobbrown1
                                  Nigel
                                  "Even on a big solid mill 7mm is too great a depth of cut"
                                  I have cut 10mm + depth with a 12mm cutter in 6082 alloy on my Marlow mill but it is a heavy solid mill but would not get any where close on the Dore Westbury mill.
                                  #162971
                                    And a 12mm cutter is going to be a LOT stiffer than a 6mm…
                                    Ed Duffner
                                      @edduffner79357
                                      If a movement of 0.1mm is detected in the quill with a DTI, but over 1mm deviation is seen in the cut, could this be a problem with the collet chuck being loose, either not tightened onto the cutter or not pulled up correctly by the draw bar?
                                      #163002
                                        Unless its a centre cutting 4-flute design in which case you can plunge and ramp with them bit like the one on the right that I was using at the weekend.
                                        #163014
                                        alan w
                                          @alanw
                                          Thanks again people. You've given us a lot to think about and to try. So we need to adjust the pre-load thingy, verify we can plunge our cutters, cut smaller slots first and finish to size on a second pass, and cut shallower passes.
                                          I think we'll print this all out and set to again at the weekend.
                                          Thanks again, Alan
                                          #163021
                                          Ketan Swali
                                            @ketanswali79440
                                            Alan,
                                            Not sure if yours is a Super X2/Super X2 Plus, as not from ARC. Regardless, your post seems to suggest that you have low or limited experience of using a small size milling machine. At ARC, we come across this/similar issue about once a month. By the time a matter such as this is raised, the machine has been 'shagged', because of lack of experience. Many of us go through this hard learning process, especially if we do not have access to the words of wisdom being expressed on this thread by the experienced users, or if we think that we are cleverer then them.
                                            I too have gone through this process – on an SX3…videos on our website on that page, being an example…where I forgot to lock down certain axis before milling/drilling, too fast speeds and feeds resulting in poor finish, and respective axis becoming loose. End result – shake rattle and role – machine shagged – get a bollacking from our experienced engineer who ends up having to re-adjust gib screws…
                                            Now that you are in this state for sure, as suggested by others, adjust/lighten gib screws, check/adjust spindle locking nut/s (depending on if it is a SIEG two nuts/non-SIEG – one nut with grub screw). Before your next milling exercise, lock non-moving X or Y axis – normally the screw with/without handle to be found in the middle of all gib adjusting grub screws. If you have a SX2/SX2P, lock in the three pronged handle which moves the head up and down on the rack, fine feed the cutter to the depth of cut you need, and then lock the Z axis gib onto the dovetail of the column, using screw with/without handle to be found in the middle of all gib adjusting grub screws. The idea is to get maximum rigidity before you start milling.
                                            Generally, for aluminium, do consider two flute slot centre cutting endmills, ideally a cutter which does not have a coating (I dont know the technical reason why). If not available, most centre cutting end mills – with/without coating will do, giving variable results based on depth of cut, spindle speed, feed rate, with/without coolant, and grade of material being cut. Oh yes, it does help to have a sharp cutter.
                                            The best way to figure this out is to experiment, but generally, start with about 0.5mm to 1mm depth of cut, and a spindle speed between 2000 to 2500rpm, spread some coolant/WD40/paraffin on the area being cut. Then start feeding the cutter into the aluminium and listen to cutter, feel the machine for vibration, and reduce the speed of spindle, and speed of feed, if necessary. If happy, experiment up to a maximum of 2mm dept of cut. You are unlikely to get anywhere with a 7mm depth of cut in one pass.
                                            BIGGEST MISTAKE I have seen/hear every time is expectation for 'small mills' to behave like a big mill/Bridgeport with higher depths of cut, feed and speed. This really gets me annoyed at first, but then I have to remember that the user probably does not have any experience of using a small mill, or this is the users first experience of using any mill. This is OK, if the user is accommodating about his lack of experience, but difficult to consider if they start going up the 'I AM so and so with X years of using a milling machine over Y number of hours (usually a big machine or a CNC machine!) ' route or 'not fit for purpose' route. We come across both types
                                            Good Luck, Ketan.
                                            #163025
                                            Ketan Swali
                                              @ketanswali79440
                                              Correction to last post: 'adjust/tighten' gib screws – not 'lighten'…
                                              Ketan.
                                              #163031
                                              Trevor Wright
                                                @trevorwright62541
                                                The problem of cutters pulling to one side happens all the way up to the largest of machines. Slots should be milled as mentioned earlier with smaller tools and finished to size cutting one face only.
                                                I worked for several years a machine bigger than my garage and never cut a clean slot in one go no matter how big the cutter. When you are using "hobby" mills, although they look pretty tough, the structure can flex under heavy loads so the;
                                                0.1mm quill play + tool deflection + machine deflection
                                                will account for the rough shape and finish of your slots. Once you accept the problem, working around it becomes the norm.
                                                Trevor
                                                #163055
                                                Anonymous
                                                  alan w: Do yourself another favour and buy a decent 2 or 3 flute centre cutting endmill. If the existing cutter is blunt, not properly ground, or of unknown parentage then that makes life difficult irrespective of the machine type and set up.
                                                  Out of interest I've just measured the width of the flywheel keyway groove on my traction engine crankshaft. It was cut in one pass (1/8" deep) with a HSS Dormer 5/16" 2 flute slotdrill held in a 'Clarkson' lookalike chuck. A 0.312" gauge block stack will just enter the groove, a 0.313" stack will not.
                                                  #164695
                                                  alan w
                                                    @alanw
                                                    Thanks all for the advice on milling in general, which are much appreciated. Last weekend, we prepared to implement the quill movement fixes proposed here, and rapidly worked out a depressing fact. Our mill is not the X2 I told you it was. It's a Super Mill XN2. I don't know if the N makes a difference – pictures on the web look identical – but I think it must because the description of what we'll find inside the quill housing is entirely wrong. What you find is just a motor mounting plate – with slotted bolt holes to allow belt tension adjustment, and another mounting plate around the quill assembly. That plate does not "hold the quill – you can remove all the bolts ad wiggle the plate but you don't get any access to the quill. And we can't remove the toothed pulley which the drive belt from the motor engages with.
                                                    Looking at the exploded diagram in the manual, it seems the quill assembly bearings (top and bottom) are a press fit into the casting. I don't know how to get it out, but moderate force is entirely unhelpful. So – we'll implement the milling methodologies you've outlined for us, but I can't see how a mill with 0.1mm play can ever machine engine parts accurately, so I think we're still stuffed until the play issue is gone.
                                                    Edited By alan w on 26/09/2014 14:31:02
                                                    #164709
                                                    Ketan Swali
                                                      @ketanswali79440
                                                      I am a little confused. Looking at the link for the XN2, I fail to see how it looks identical in any way with the X2 or the SX2:
                                                      Am I missing something?
                                                      If you purchased from Axminster, then it looks like this with a different paint job:
                                                      If so, it is closer in resemblance to an SX3. there is a dismantling and reassembly guide for the SX3 here:
                                                      http://www.arceurotrade.co.uk/machineguides/Super-X3-Mill-Dismantling-and-Reassembly-Guide.pdf
                                                      Maybe you might find some similarity in the SX3 guide.
                                                      I am guessing you purchased the mill from Axminster. If so, have you considered asking them or whoever you purchased the mill from?
                                                      Ketan at ARC.
