So do I and call them crimp lugs.
There are now many Hi Tech systems for joining things together. Copper pipes can be joined by crimp connectors instead of soldered fittings which is very usefull when working on old listed buildings. Cambridge colleges insist that plumbers remain on site for at least one hour after using heat and they must obtain written permission before hand to do so. Notthe case with crimp fittings.
Trade names are XPRESS MPRESS etc
I had the chrome pipes in my bathroom towel rail done with stainless crimp fittings and it looks the buissness. The only other way would have been compression fittings which look bulky and out of place.
Most of our lab plumbing is in plastic and the joints are thermally fused. For the life of me I cannot remember what the trade name is but the fittings have terminals and internal resistance elements. The pipe and fittings are assembled and the battery driven power unit is attached. Hit the button and a controlled currrent is delivered for a set time. This thermally bonds the joint.
All these system are expensive in consumables but reliability is better and the avoidance of gas flames very benificial allowing joints in some very awkward places. It gets expensive when you burn buildings down too.
regards Martin
