I am working on a spring driven motor, the large wheel has a diameter of 200 mm. It drives a first wheel in a governor that has pinion of 14 mm diameter with 12 teeth which is a new replacement made by someone in the past. It looks nicely made and works fine with the large wheel, problem I have with it that the pinion is not hardened, probably made of a free machining steel or similar. My question; is that OK or should I make a new pinion which is hardened and tempered, what do you think? Niko.
Edited By speelwerk on 17/04/2020 18:38:11
