Posted by John Gardener on 22/02/2017 17:41:38:
Martin, yes, my post isn’t clear, I did mean the chuck.
Bazyle, I have the Clark CMD10 which of course, came with the drawbar for the drill chuck. I bought a set of Posilock 2MT which did not and of course are a different thread, bought in the days when I knew even less than nothing about machining. Even making a drawbar was a bit of a challenge then.
I thought I might look at the ER type as they seem to offer a better range of sizes, some, as Martin says, do offer a chuck complete with drawbar and even specify the thread.
Whilst I realise that given my budget, and that I am reluctant to spend a huge chunk of my ‘disposable’; I am going to get ‘cheap imports’ rather than precision German ones for instance, I thought that I might purchase from a UK based company as this one had them in stock. I also realise that companies like Chronos/RGD /ARC etc. import stuff but not in my budget range. In truth, I want something to take an 18mm Ball nosed end-mill for the base pins in my earlier post which will, I hope give me a better profile than running a 16mm, the biggest I can find a Posilock, back across the work repeatedly. Am I making sense here?
Anyway thanks guys, all this is very helpful and most welcome.
Whilst you might find some means of holding an 18mm ball nosed end mill in a Clarke CMD10 I cannot imagine it doing any serious, or even near serious, removal of metal. It might be you are machining plastic or wood in which case it should cope but the CMD10 is a small machine withe limited workspace volume, a lot of the daylight at least, will be lost with the cutter holder you end up with.
Whilst not having the size flexibility of ER collets, direct MT2 collets are the best option for the CMD10. If you want to use ER then the holder has to fit in the MT2 spindle taper and moves the cutter further from the spindle bearings and the rigidity is made worse. ER16 might not be too bad but ER25 or 32 are really not to be recommended.
I could not see any reference to 'Base Pins' in your earlier posts but reitterate that an 18mm diameter cutter is a bit risky in such a small, low powered machine.
Ian P
