Water filter for injector
Home Forums Beginners questions Water filter for injector
  • #111397
    nigel jones 5
      @nigeljones5
      Hi…where do i get one or how do i make one?
      thanks
      nije
      nigel jones 5
        @nigeljones5
        #111400
        FMES
          @fmes
          Where are you located Nije? a lot of home Diy stores do a sink side filter tap which has a seperate cartridge.
          #111401
          David G
            @davidg
            or something like this filter , ebay has lots…
            I might need to fit a filter to the Club Peckett when I take it over as the injector often gets blocked. making one would probably look better and be more robust.
            Mark P.
              @markp
              I make them from brass gauze. Make a nut to fit the feed pipe in the tender,drill a hole through the nut,put a 20mm dia x 1mm deep counterbore in the top end of the nut,solder the gauze into the counterbore there you have it a filter removable for cleaning. Some on ebay.
              Regards Mark P.
              #111415
              David G
                @davidg
                like the idea Mark, not sure how you would retro fit this to a saddle tank.
                I have found these that could be made into an inline filter, ordered some so will have a go at some point.
                Boiler Bri
                  @boilerbri
                  Looking at this post it answered one of my questions and i bought some brass screens.
                  I have looked through my old ME mags to try to find a steam valve drawing all the ones i can find are either 3/16 (for 2-1/2" guage) or big ones 3/8". has anyone got a drawing for one for 1/4" x 40 that they can let me have?
                  The valve will be used for the steam feed to my new injector.
                  Bri
                  #122617
                  MICHAEL WILLIAMS
                    @michaelwilliams41215
                    Fit a large area gauze filter just under the tank filler . With the tank cleaned out when new very little contamination can now get in and any line filter in injector pipework will have little to do and rarely need cleaning .
                    Make the tank filler filter very simple – drop in and make easy to pull out . A basket shape is best .
                    As regards the line filter for the injector have a good big free flow area to avoid bubble clogging .
                    MikeW
                    Edited By MICHAEL WILLIAMS on 18/06/2013 23:17:03
