Hi David
thanks for the reply
so far i have removed the gib strip and examined it for burs and straightness. All seems as it should be
i have also cleaned the area as you recommended
just about to oil and reassemble however the gib strip does not go as far in as it used to. Protruding by about 5mm. I did a video when i first got the mill, 2017, as it not sticking out as much then. Also because its sticking out 5 mill the screw at the head end bottoms before touching the end of the gib
peter
