Warco oil can replacement
Home › Forums › General Questions › Warco oil can replacement
  • #293570
    petro1head
      @petro1head
      The oil can I got with my Warco lathe leaks. Its leaking where the plunger enters the can.
      Is there a fix or should I invest in a new one that does not leak? If so any suggestions as to which one?
      #25187
      petro1head
        @petro1head
        #293572
          I keep the supplied one for head oil as you don't need to tip the can up to fill the head or apron gearboxes. For way oil I use a small Reilang can that suits the ball oilers and works well at any angle without leaking
          #293594
          petro1head
            @petro1head
            Thanks Jason
            There are quite a few on ebay, some new, some used.  Am I better buying a new one or going for a vintage/old one
            Edited By petro1head on 16/04/2017 12:37:11
            #293609
              All my oil-cans leak, some worse than others. People say nice things about Reilang but they ain't cheap. Not much should be expected of a vintage oil-can; think "worn-out" rather than "quality".
              Stewart Hart
                @stewarthart90345
                You could always make your own
                Stew
