Warco Ball Joint Clamps – usefull?
Home Forums Beginners questions Warco Ball Joint Clamps – usefull?
  • #286070
    petro1head
      @petro1head
      Saw these and just wondered if anyone else has them are re the any good
      petro1head
        @petro1head
        #286074
        Clive Foster
          @clivefoster55965
          There was a thread on this sort of thing about 6 or 8 months back. I think they were among the varieties discussed. General conclusion was fine if they fit the work you do. I'm not sure that I really understand the need for the ball joint bit. Have heard that similar DIY versions with simple pivots at the bottom and a half circle pin at the top work fine. At that price its a fairly fine line between make or buy anyway.
          Clive.
          PS They are quite long and sprawl out rather.  Especially if holding thinner workpieces.  If you have a smaller machine best to mock up and check how much space you have.  Probably not ideal as your one and only set.  Can't see them fitting on smaller rotary tables for example.
          Edited By Clive Foster on 26/02/2017 12:53:38
          #286076
          Ian Parkin
            @ianparkin39383
            I have a pair and wouldn't want to be without them
            #286090
            petro1head
              @petro1head
              Posted by Clive Foster on 26/02/2017 12:36:23:
              Just ordered a Warco WM18 so I think it would be ok
              #286165
              Enough!
                @enough
                I have a pair and rarely use them. They frequently don't fit what I'm doing and by the time I've fiddled about with them it's quicker to go with regular clamps/blocks.
                Mine (from LMS) had springs on the screws under some misguided apprehension that this actually helped somehow. It took me ages to realise I should get rid of them and they are somewhat easier to use without. Still don't use them much.
                To each his own, I guess.
