wanted easy usable free td software please
Home › Forums › CAD – Technical drawing & design › wanted easy usable free td software please
  • #84582
    garrygun
      @garrygun
      Hi guys, im looking for a EASY usable free download technical drawing software,
      i have down loaded two so far but both are not what i want and are not user friendly to me, i would like something like isometric 3d if there is one, i use iso graph paper at the moment but would like to do this on laptop.
      Any help would be appreciated.
      Thanks Garry.
      #21131
      garrygun
        @garrygun
        #84583
        jason udall
          @jasonudall57142
          google sketchup?
          #84627
          Russell Eberhardt
            @russelleberhardt48058
            All worthwhile CAD software takes a bit of work to learn.
            Try this: DraftSight. It is a free 2D package but will do isometrics and 3D wireframe and is compatible with the industry standard Autocad.
            Russell.
            #84795
            garrygun
              @garrygun
              Thanks for the replys, i tried google sketchup couldnt get on with it, but i will try again maybe im too impatient.
              going to look at draftsight see what its like.
              #84797
              jason udall
                @jasonudall57142
                couldn’t get on with early sketckup me’ self
                Latest(8?) better.
                Best I have used is autosketch…not free but closest to feel of draughting engin to me…used auto cad various from ver 3 on wards… So un natural…
                But like I say autosketch..but will probably need some instuction..so look into source of tutorial etc tnen look at programme
                #84889
                Russell Eberhardt
                  If you’re used to Autocad try DraftSight. It has the look and feel of Autocad a few versions back. I used Autocad from v. 1.4 onwards and find Draftsight a good free replacement.
                  Russell (no connection just a satisfied user)
                  #84913
                  John Hinkley
                    @johnhinkley26699
                    Garry,
                    I, too searched the net for a freeware CAD package. Luckily for me, I have a laptop which runs Linux OS (ubuntu), where software is 99% free and LibreCAD (and its clone QCAD) are both simple, effective CAD packages, which read and write .dwg and .dxf filetypes – i.e. AutoCAD compatible. I also have Draftsight both computers, but although it is a comprehensive program, I find it too complicated to produce the sort of drawing I, and it sounds like, you, are trying to make. When in the UK last Christmas, I picked up some parts in a Maplin store. While waiting to be served, I was tempted by a disp[lay of DVDs near the till. One was TotalCAD2D/3D and set me back the princely sum of £7.95! It's fully-featured and comes with a very good help file, supports multiple filetypes and is quite easy to learn. I don't know if it was a special, one-off offer, but I would recomend it, if you can get hold of a copy. If you don't like it – you won't have spent small fortune.
                    The Merry Miller
                      @themerrymiller
                      John,
                      Have just ordered a copy from Amazon @ £5.97. (free delivery)
                      Worth a shot.
                      Len P.
                      #84930
                      Russell Eberhardt
                        John,
                        I too run Linux and have QCAD. It supports .dxf files but not .dwg. Don't know about LibreCAD, I've not tried it.
                        TotalCAD looks good. It's a shame it is only available for Windoze. Have you tried it in Wine or on Windoze running on Virtualbox?
                        An important point for me is being able to accurately print 1:1. . It makes life much easier when cutting awkward shapes to be amble to print the draying and stick it to the work with artists spray mount and cut along the lines.
                        Russell.
                        #85247
                        Les B
                          @lesb
                          Take a look at this site, for free cad etc, then maybe take your pick.
                          http://www.freebyte.com/cad/cad.htm#2D3DCADSystems
                          Les B
                          #85252
                          Mark P.
                            @markp
                            You could try e machineshop it's free and quite user friendly.
                            Regards Pailo.
