I have an elderly Victoria Mark 1 ‘H0’ horizontal milling machine, the details of which can be found on the excellent lathes.co.uk website if anyone is interested – here:
http://www.lathes.co.uk/victoria/page2.html
I also have a full set of ER32 collets and various chucks to fit my Myford, Lorch and EW lathes – so decided a nice suggestion to Santa for my Xmas stocking might be an INT/ER32 chuck for Vicky. This would then give me something that looked rather like a very robust ‘lathe’ headstock with ER32 capability working on a very large powered vertical slide! Sounded useful.
Now for some reason I’d always assumed the spindle nose on the HO was a No 30 INT – but the ‘Lathes’ site states it to be No 40. For reasons I won’t bore you with, I am unable to get down the ‘Shed’ at the moment to measure the mill directly, but instead dispatched one of my ‘off-spring’ to bring the horizontal arbor up to be measured. Referring to Machinery’s handbook the key dimension seemed to be ‘A’ (Gage diameter of flange).
This gives INT30 as 1¼” and INT40 as 1¾”. Seemed simple enough until I measured what I took to be the same dimension on the arbor (directly behind the flange) which was 1.375” (1.3/8th). So I seem to have an INT35 spindle taper?
Well, probably not, but I’m clearly missing something here. Can anyone help me please?
By the way, on the subject of milling machines generally and the questions about what to buy?
The main advice seemed to be to go for mass and rigidity etc. The Victoria probably weighs a ton or more and is built like the proverbial brick outhouse. They simply do not make machines like this anymore and whilst it is limited in some ways (spindle speeds for instance) it has a large powered table and doesn’t flinch at cuts that I suspect would cripple most small modern machines. It cost me a few hundred pounds to buy, plus the hire of a twin-axle trailer for the day and the loan of a 2-ton engine hoist (plus a friend’s much needed muscle). If you have room for an older machine, they can be the basis for much improvement and may well suit those who have more time than money to spare.
IanT
