Here is my view of this waffle of 29Hz.
Electric motors rely on resistance, reactance, back emf’s, core saturation, etc. in their design to perform effectively with the prevailing name-plate supply. Deviation from that voltage will alter the motor characteristics – output power, efficiency, torque, etc while a deviation of frequency will alter the basic speed of the motor – again affecting the original design characteristics.
For the reasons above, I think the 29Hz is unlikely to be set in stone as the frequency at which the writer suggests this phenomenon occurs.
Simple physics shows that at zero rpm (start-up point) the current drawn by the motor will be initially a reactive circuit, but very quickly becoming a resistive current – unless that motor actually starts to turn (stalled motor at start up will either trip the motor overloads, blow the fuse, trip the mcb or burn out the motor windings).
At design voltage and frequency the motor should provide the name-plate output.
Between that frequency and zero Hz, the motor would take more and more current because it would revert towards a resistive circuit as the supply tends towards driving a resistive load. That is OK up to a point.
If that increase is due to mechanical overload slowing the motor, it would surely burn out long before the speed dropped to the equivalent speed of 29Hz whilst being driven by the normal supply frequency!
If the speed is reduced by a controlled frequency reduction, we have a different scenario. The current would tend to rise, but the motor power would be reduced because the VFD sorts out the voltage to maintain the safe current. (This is apart from the extra problem of a slower moving fan which was initially designed to cool the motor at its normal supply frequency). At some point, the motor torque will no longer be attained without eventual damage to the windings – the escaping magic smoke! – and that, presumably, will be around 29Hz.
Most motors will be designed within a fairly close range of working parameters. The better motors will be more expensive to manufacture, of course (more copper, better insulation, higher temperature resistance, higher run cycles, better controlled cooling, etc).
The simple way to avoid trouble, for us hobbyists, is not to overload the motor -particularly at lower frequencies – and to limit the run/rest cycle to below whatever it was rated at for normal frequency running. Forget about this supposedly magical figure of 29Hz, apply some common sense and just get on with life.
