Unimat 3 milling spindle bearing upgrade
Home › Forums › Manual machine tools › Unimat 3 milling spindle bearing upgrade
  • #423510
    Former Member
      @formermember32069
      #13612
      Former Member
        @formermember32069
        #423559
        Kiwi Bloke
          @kiwibloke62605
          Well, I'm full of admiration for someone who fixes a problem so swiftly! In disgust at their bearing slackness, I packed away my Unimat milling heads and tried to forget about them. Perhaps motivation will now return…
          When you had the quill apart, did you investigate whether a standard-sized ball bearing could be fitted into the nose end of the quill as well? Presumably, it would need to be bored out, as at t'other end.
          #423581
          Former Member
            @formermember32069
            #423603
            Kiwi Bloke
              @kiwibloke62605
              Barrie: thanks for your encouragement and offer. I've no idea when I'll get one of those round tuit things… Where did you go for Bellville washers?
              I see that Simply Bearings (from whom I've had excellent service) have 15mm ID bearings in 20, 21, 24, 26 and 28mm OD. Perhaps this makes a nose-end bearing swap practicable. What do you think? My spindles have a lot of radial play at the nose end, so I'd want to attack that end as well.
              #423632
              Former Member
                @formermember32069
