Thankyou Jason.
No, Michael, those are genuine photographs… Taken at the Great Dorset Steam Fair some years ago.
That is indeed the vehicle, or rather a modern replica. I do have those photographs, sent me by someone… or I did. I seem mysteriously to have lost quite a number of photos and all around the time the Seattle lot “up-graded” my computer from WIN-10 to 11. They might be still on my previous PC if they are not in Mickeysoft’s server “cloud” .
However, I have not seen that lorry for myself. It was built to commission by Richard (‘Turbo’) Vincent and I tried to ask its owner if I could visit it, but he was reluctant to let me. Understandably, perhaps.
I do not know where it is, nor if it ever appears anywhere else. I have not heard of it doing so, and of course the GDSF has died.
I did though visit that replica under construction, though at that stage it was just a chassis frame on trestles, and a boiler. I think it was Mr. Vincent who sent me the photo I posted a few messages back, and he admitted having no more infomation than I did. He wondered about modifying a Sissons engine, also an inverted-vertical, enclosed machine, and I do not know if that is what the replica has.
On the other hand Richard Vincent is a professional preservation engineer with far more experience and facilities than I have.
Despite the low light level, that marquee photo does show the transmission is two-speed, though not how you change gear; and the peculiar way to let the steam at the engine. There is also a faint hint of a lever with trigger, below the regulator: the reverser?
It also shows the steering-box used on the Hindley “Standard” wagons, hinting different gears (worm and quadrant or screw and nut).
Hindleys did not like to standardise parts too much. That prominent gear-frame plate on the nearside, in the outdoor picture, is different on every photograph showing it, but all show it carries the radius-rod pivot, presumably axially with the sprocket shaft. I have used a commercial rose-joint between two plates: they are reasonably discreet. Slightly less discreet on the Ackermann steering whose original was all clevises, but I don’t want to emulate M. Cugnot’s unfortunate driver!
I cannot identify the blackness beyond where you’ve placed the sketched sprocket.
The outdoor photo hints something unexpected. The steering-column looks not only raked aft-wards as you’d expect, but also to starboard. Original photos including the driver do suggest the column was inboard of his left foot. They didn’t want it too comfy for him!
It also reveals a big, inverted-arch stretcher under the boiler, and on mine it carries a hardwood V-block, boiler support.
I have met someone who has briefly driven that replica. He confirmed the regulator at least on that specimen is that arkwardly-placed globe-valve (for rapid shut-off?), and said driving it is not easy! My answer for my model, given how one has to drive such a model, and my making the engine simple-expansion, is to use what I think the starting-valve as the regulator and leave the globe-valve open, closed only for the hydraulic tests.
Still, I have never claimed mine is a rivet-counter’s special, but tries to represent an average of the originals as well as it can. This “Light Delivery Van” appeared to have been built in different chassis lengths, and I have made mine the “Lightest”, perhaps slightly under-length on the chassis. It’s also fractionally under scale width… so it fitted through my house door. Not that anyone would know or notice. The Vincent replica seems of the longer variants. That long-ways chassis in my photo, with water-tank ahead of the axle, was probably of short form to take a tipping body.
There IS another 4″-scale model already built, by a member of Taunton MES, but I do not think he still owns it, have lost touch with him and I do not where that model now lives. I saw it, static, at that Society’s exhibition maybe twelve years ago now; but did not meet its owner.
