Tube cutting
Tube cutting
Home › Forums › Beginners questions › Tube cutting
  • #279644
    Roger Hulett
      @rogerhulett83124
      I wonder if anyone has any tips regarding the accurate cutting of thin walled (.75mm) large diameter (125mm) stainless steel tube.
      What tools to use etc…….Thankyou
      #8518
      Roger Hulett
        @rogerhulett83124
        Tube cutting
        #279651
        Speedy Builder5
          @speedybuilder5
          Thin cut off disc, there are special discs for SS.
          BobH
          #279653
          Emgee
            @emgee
            Chop saw with the capacity and blade to suit.
            Alternatively a suitably thin blade in a hand held 100mm + mini grinder, first spin it on an indelible marker to help make a square cut.
            Emgee
            #279657
            Gordon W
              @gordonw
              Thin 1mm cutting disc. Or maybe better if a lot to do, a cutting tool as used for exhaust pipes, very good. Local garage might do a one off for you.
              #279659
              richardandtracy
                @richardandtracy
                Whenever I hear someone say 'Accurate' I always want to ask 'How Accurate?' as that will have a fundamental impact on the method of cutting. An other thing to consider, too, is if you can machine post cutting? If the response is 'Accurate to microns and no post machining' then you can almost only be considering electron beam/laser cutting, while 'Accurate to nearest half inch' could imply a hand held angle grinder. With anything in between being determined by the actual answer.
                To give an answer before the 'how accurate' question is answered is, in my view, premature.
                Richard.
                Edited By richardandtracy on 23/01/2017 14:17:55
                #279728
                not done it yet
                  @notdoneityet
                  R&T, apart from accuracy (or precision, if only repeatability is required) I would also like to know if this is a 'one off' or series cutting procedure. A former and pipe cutter would likely suffice, or former and lathe cutter?
