Trying to choose a diamond grinding wheel
Home Forums Workshop Tools and Tooling Trying to choose a diamond grinding wheel
  • #235315
    Geoff~
      @geoff46085
      Hi all,
      I want to replace one of the grinding wheels on my 6" bench grinder so I can sharpen my turning tools (brazed carbide tipped) and tungsten carbide masonry drills.
      Reading past threads suggests that diamond wheels are the way to go but I'm totally confused by the different array of shapes available. An example of what I mean can be seen here at Arc's page..
      So my question is, what shape is for what purpose and what would be recommended for my needs?
      thanks in advance
      Geoff
      Geoff~
        @geoff46085
        all those different shapes!
        #235319
        Chris Evans 6
          @chrisevans6
          I run the 45 degree dish style on one end of my grinder with good results on the same things as you wish to do.
          #235710
          Neil Lickfold
            @neillickfold44316
            I like the cup wheel myself, but the cup or 45 deg wheel's are good.
              I have a 45 degree wheel, replacing it I would get the cup, as it takes up a bit less room. As a second wheel I will probably get a tapered on some time, for gashing cutters.
