Just to remind folk that the original question was regarding the math for shimming..since I was feeling particulalrly dense at the time.
That is a bit moot right now. I've just been rechecking and the sideways tram was out again. One of the problems with this model is that it shifts as you tighten the head bolts and I'd obviously not doged them donw enough last time anyway. After much pratting about Ive got it to 0.03mm over a DTI width of about 18cm. Not as perfect as I;d have liked but the head bolts are dogged as tight as my 18stone can lean on them.
Right now the nod has gone.. so evidently the head bolt tightness affects the way the head sits against the main pillar. Whether there's any effect fro the shed cooling and then the woodburner heating up again… well i'll see how the sideways tram is tomorrow.
I also didnt have the quill lock engaged last time which might also affect things.
0.03mm over 18cm.. well the widest cutter it's rated for is 80mm and at that the sideways variation would be 0.014mm'ish ..just over a half thou in imperial over the cutter face. So for a tyro about to skim his first metal it's close enough.
Incidentally my first message math was near enough -.shim thickness half the DTI difference proportioned to the DTI spread compared to column bolt spread.. although i drew a cheat pic to get my head around it. It may still need to be shimmed..but no point rushing into that.. a few more days of checks and measures to see if anything moves. I still have to check quill lock on/off and indeed whether how far the quill is out matters
