Tooling Choices, identification & WM290 Feed Question
Home Forums Manual machine tools Tooling Choices, identification & WM290 Feed Question
Viewing 23 posts - 26 through 48 (of 48 total)
  • #455066
    DMB
      @dmb
      JasonB,
      Thank you for your how to post above. Will make a note of it for future use.
      Anonymous
        Posted by Dave Brannigan on 02/03/2020 10:39:39:
        As for Andrew J's comments on speed, don't blame the machine. I'm just scared to wind it up but it sounds like I need to.
        Don't pussyfoot around, give it some welly! If nothing else with a VFD drive you'll have more power available. As an example I was turning this flywheel at 60rpm:
        But it is over 16" in diameter.
        #455100
        Dave Brannigan
          @davebrannigan15528
          Thanks Jason. Seems like I still need to faff with the album to get it on the site before it can be plucked out and pasted then. Bit clunky but if that’s what it is…
          I guess my clutch is slipping because The tools I’m using are not sharp enough or I’m abusing them by not working the cutting tool hard enough with enough speed. I’ll try abusing it a bit and see what happens.
          I put a power meter on it whilst I was cutting and it only pulled about 400W. I have 1100 to spare so I’ll give it some stick. What’s the worst that can happen?
          Cheers guys.
          #455106
          Martin W
            @martinw
            Kevlar body armour, hard hat, several pairs of safety goggles and you will be fine.
            #455111
              Even at the slow speeds the machine should have cut without slipping unless you were taking a silly depth of cut. Check the cutting edge is exactly on the centre height of the lathe, too high and the tool will rub and drag.
              #455113
              Dave Brannigan
                @davebrannigan15528
                I’ve been using the steel rule gently pressed between the tool and some small diameter bar in the Chuck method for centring set up. Could well be down to speed asi was on small diameters that the stalling was worse. I’ll get the flack gear on and see what she’s capable of at some point. Just not today😀
                #455114
                  I've altered the title which may attract the 290 users to the thread.
                  #455129
                  Tony Pratt 1
                    @tonypratt1
                    I’ve had my WM 290V for some months now & fairly pleased with my purchase, it’s certainly rough around the edges compared to my old super 7 but it’s a step change in capabilities.
                    It can really shift the metal & takes hefty cuts in steel with no problem [need to sort out some better guarding] with no sign of the feed screw clutch slipping, maybe it’s locked up tight?
                    I can’t comment about the change gears etc. as I have fitted the electronic leadscrew kit as promoted by Clough42 on YouTube, a brilliant game changer in my opinion.
                    Tony
                    #455152
                    Dave Brannigan
                      @davebrannigan15528
                      I can see the change gears becoming a pain if I did a lot of threading but at the moment I'm just playing. I guess determining a suitable feed rate to cover a range of applications will be a good place to start. At the moment I have it set to, you guessed it, the slowest. but I'll try faster I promise.
                      Id be interested to know if your change gear tables had the same errors as mine – even if you no longer use them.
                      As to that motor driven leadsecrw mod, I watched episode 1 in full and skipped through subsequent ones. It looks fantastic but I think I'll see if I can master the basics before investing further. What kind of money was it as a matter of interest? Is there a UK seller?
                      Cheers
                      Tony Pratt 1
                        @tonypratt1
                        I will have a look at my change wheel tables when I get a chance & post pictures, as to the electronic lead screw I suppose just over £100 would be a ball park figure, I didn't keep count so that's only an estimate? All the details are on Github & a board can be purchased from Clough42 via Ebay, all other bits are readily available online from the UK or China.
                        Tony
                        #455169
                          I've had my 280 which is very similar in the feed department for over 10 years and not found the need to use anything else but the finest gear train. Just use the 3 position lever to get different rates that seem to suit what I do.
                          By way of comparrison to what you may be getting this is how brass should cut with HSS and inserts
                          And they will take quite a big cut in steel but not something I would suggest you do on  a regular basis, 1" bar down to 1/2" in one pass
                          Edited By JasonB on 03/03/2020 13:14:44
                          #455181
                          Anonymous
                            I change feed rates on a regular basis, if only because the cross feed is half what is set for the axial feed. For most general turning I use 4 thou/rev. Very occasionally I'll drop down to 2 thou/rev, but have never used the lowest feedrates.
                            When roughing I up the rate to 8 or 10, or higher, thou/rev depending upon material and depth of cut. An increased feedrate can also help with chatter when boring.
                            #455186
                              That's basically what I do Andrew with my 3 speed lever once the basic gear train is set. C gives me fine turning and A rough turning then for the facing cuts which like your M300 are at a smaller 1/3rd A gives me the finish feed and B the faster roughing. Those of us without such a selection in the gearbox have to make do with what we have.
                              Edited By JasonB on 03/03/2020 17:26:27
                              #455253
                              Dave Brannigan
                                @davebrannigan15528
                                So based upon the tables posted which feed rates are you using for the baseline of your cuts?
                                  None as mine is imperial  and you probably have a bigger driver on the spindle due to the larger bore but basically the finest range eg that on the left.
                                  Let me get back to you as I want to double check what's printed is what I'm getting so I will take an actual measurement later to confirm. been a while since I did it and can't remember the feed shaft gearing within the apron.
                                  There does look to be something amiss with your metric chart as the turning (along the lathe) rate is almost 10 times faster than the facing (across) yet the imperial is only 3 times even though they share the same apron internals and feed shaft with only the leadscrew being different and that is not used for feeds.
                                  Edited By JasonB on 04/03/2020 07:27:37
                                  #455294
                                    Had more time than I thought this morning so using a plunger dial gauge and turning the chuck 10 revs in position "A" confirms my imperial chart is correct.
                                    Turning along lathe axis usual feed rate "C" = 0.0025" (0.06mm) roughing "A" = 0.005" (0.12mm) Seldom use "B" which is 0.010"
                                    Facing usual finish "A" = 0.0015" (0.04mm) roughing "B" = 0.003" (0.08mm) Seldom use "C" as it is really fine @ 0.00075"
                                    #455390
                                    Dave Brannigan
                                      @davebrannigan15528
                                      So the plot thickens and the errors found continue to grow in my change tables. Maybe. Read on.
                                      Using Jasons method I've indicated my slide movements using the smallest incremental gear set of
                                      45 75
                                      80 20
                                      H 85
                                      With 10 turns of the chuck I get:
                                      1.457mm with A
                                      2.798mm with B
                                      0.721mm with C
                                      All as per the table give or take a few degrees of chuck start/end position variation.
                                      However with the cross slide I get:
                                      0.357mm with A
                                      0.724mm with B
                                      0.166mm with C.
                                      OK C isn't shown on the table as it's deemed too small to be bothered with, but for A & B it is travelling twice as far as it ought to according to the table. Now this may be the way it's supposed to be – to do with the radius being half the diameter or something. Like I said I am learning all the way and happy to be educated, but surely the figures on the tables should be a linear distance and not a function of diameter etc?
                                      If I'm not mistaken this will be yet another point to feedback to Warco.
                                      Cheers
                                        Well that is better than what the table shows and looks like your apron actually has a 4:1 difference between turning and facing feeds whereas mine is 3:1. which is a bit of apain to find a happy set of ratios without having to swap the gear train all the time. Would be interesting to see if Dave could measure his metric 280 and see what that gives.
                                        As you say the feed rate on the lathe is amount tool moves per rev so remains constant irrispective of diameter or radius.
                                        #455527
                                          Posted by JasonB on 04/03/2020 17:17:56:
                                          … Would be interesting to see if Dave could measure his metric 280 and see what that gives.
                                          With the machine geared 45 80 20 85 (as per Dave B):
                                          Actual Plate
                                          C 0.015 0.03
                                          A 0.03 0.06
                                          B 0.06 0.12
                                          Actual being half the Plate value makes the Plate consistent with the lathe's dial, which is graduated to show 'amount removed off diameter' rather than 'distance moved by cutter'. Dial graduation is six of one and half a dozen of the other. Being graduated in amount removed is convenient for most turning to diameter tasks, but is half the required value when cutting fins or threads to a depth. Graduating the dial in distance moved is great for threading and fins, but means mental arithmetic when turning to diameter. I don't think it matters.
                                          I suggest to Dave B that Plate mistooks are low-priority, because right or wrong the plate doesn't matter much. What matters is the lathe's actual performance. Typos are just annoying. A missing gear from the change set would stop work entirely. Likewise, the gearbox refusing to change gear, smoking motor, refusenik speed control, fuses popping, electrical tingles, damaged ways, excessive run-out, bent lead-screw / half-nuts or wobbly bearings etc are immediate cause for concern! The best way to identify important problems is to use the lathe. I feel almost the worst thing a beginner can do is start with a deep inspection and measuring spree, especially if any of it involves dismantling the machine. It's too easy to get confused or misled. Better to use measurement to diagnose real problems rather than discover theoretical ones.
                                          I recommend making several things. Start simple and move up. The more the lathe is used, the better it will be understood – good and bad. All lathes have shortcomings, quite often they're not important. If there are any show-stoppers, using the lathe should quickly flush them out.
                                          Cutting metal will also show how good or bad the operator is! I've discovered I'm never going to win any competitions. By nature I'm an impatient bodger mostly making stuff for practical reasons. Truth is I lack the patience and attention to detail needed to do the best work. Love to blame my Chinese Lathe for ugly results, but the problem is mostly me. It's not the machine – I can make decently finished stuff simply by taking more care…
                                          Once familiar with a machine, absolutely OK to pull it apart and make improvements.
                                          Dave Brannigan
                                            @davebrannigan15528
                                            Interesting view, but please do remember that within a few days of receiving the machine I tried cutting an 11 TPI thread and it failed which is where all the uncertainty with the accuracy of the tables emanated from. As a beginner I trusted the data provided and it didn't work. I don't feel that I should need to get a calculator out each and every time I want to select a particular pitch. That's what the tables are for surely?
                                            It seems there is disagreement on the numbering on the cross slide tables as Jason says it is a linear distance – same as the Z Axis, but sillyoldduffer says it is a function of the radius being half the diameter thus moves twice as much etc.
                                            After Jason's comment I reported this back to Warco and they have forwarded it to China. Didn't say whether it was right or wrong…? Maybe there is more than one convention?
                                            I guess I'm a bit data driven. If I see something in a manual I expect it to be right especially on something that's been around for a while. Would have thought any bugs would have been sorted by now.
                                            Turning is only a pastime for me. I get to play once or twice a week at best and then not for long. I guess Ill get better with time, but Id like to bottom out basic errors on the tool before I learn to adopt the mistakes and then relearn it after it gets corrected.
                                            Though I haven't had anything on fire yet I have had a fault with a contactor that prevented the VFD from running at all. Big chunky contactors were never intended for switching 5v DC signals for fwd and rev but that's what is fitted and all it took was a little oxide on the contacts and my 1 day old lathe died. It oughta have had two small relays, one low voltage for the 5v signals and a separate one for the control switching which is all 240vac.
                                            Again fed back to Warco. Whether they'll do anything about it is another matter. I'll mod it for reliability sake after warranty expiration.
                                            Cheers,
                                              Posted by Dave Brannigan on 05/03/2020 15:51:10:
                                              Cheers,
                                              No criticism intended! It's just a certain amount of pragmatism helps me get on with Far Eastern machines. And over the years I've been on the forum, a fair few chaps have got flustered due to starting with a theoretical examination of their new machine rather than successfully using it. I reckon faults that don't make a difference in the real world should be ignored! For example, your lathe can cut 11tpi despite the plate being wrong.
                                              What should be expected of a hobby lathe costing less than 20% of its industrial equivalent is discussed endlessly on the forum. Some expect hobby machines to be just as good as professional machines, which I feel is unrealistic! On the other hand, what we have delivered into our workshops should certainly be better than a 'kit of parts', which was how too many of these machines were described when they first appeared. Although most of us get acceptable machines now, there are still occasional horror stories. They don't worry me much because the risk is low – bad examples can be exchanged for a better one or money back.
                                              My experience with 6 Far Eastern machines is of finding minor issues only. Mostly due to rushed assembly and indifferent finish – nothing serious. Everything I bought worked out of the box with no fuss, but it all benefited from some gentle fettling.
                                              For some, finding even minor issues on a brand-new item is unacceptable. And who am I to disagree? I just accepted inexpensive machines are likely to be a bit rough and did the necessary tweaking as faults emerged. No regrets, I've used a WM18 mill for 6 years and a WM280 lathe for 5 years with no issues, touch wood.
                                              While they've both done what I want of them, I wouldn't claim they are the best machine tools in their class. In particular, I take care not to push the machines too hard, preferring them to sound moderately strained when cutting rather than laboured. Actually, I've never got the 1.5kW motor on the WM280 to warm up, despite taking deep fast cuts in carbide that cause an overly exciting spray of red-hot steel chips!
                                              Re linear vs function confusion, I think that's just interpretation of words. I agree with Jason that the movement is linear in that it depends only on the gear settings and motor speed, and doesn't vary with distance from centre. Radius and diameter are a red-herring, I only meant the plate is consistent with the dial. In practice the plate doesn't matter much – apart from threading I leave the gears set for facing (45 80 20 85) and switch between C, A & B to suit the job. I've never actually used the plate for that purpose – eyeballing during the check phase is enough to show the tool moving too quickly. The plate might be useful as a guide to facing when gears happen to be set-up for threading; usually facing isn't advised with the gears selected for the coarse threads I usually cut.
                                              By 'check phase', I mean the pre-flight checks taken after setting up and before applying a powered cut. Make sure the job revolves without hitting anything, the saddle and cross-slide are clear, the stop is positioned correctly, slides locked or unlocked as appropriate, forward/reverse, gears, interlocks, and other controls engaged correctly, and any other sanity checks. For example, after changing gears on the banjo I always double-check the resulting pitch by running the tool point by hand sufficient to scratch a few spirals. It's because I get the banjo wrong 1 in 6 attempts by misreading my notes or misplacing the gears. Shameful but true…
                                              Edited By SillyOldDuffer on 05/03/2020 17:30:35
                                              #455593
                                              Lofty
                                                @lofty83899
                                                Dave B, I was wondering the same thing the other day as to why they have a 20amp contactor for switching 5 volt 10ma.
                                                There is 240 volt feed wire conected to 43 on the contactor is for a built in fan on the back end of the three phase motor, this is switched via the forward /off /reverse (10 – 9) switch and is not using the contactor to switch, I was geting a lot of EMI swiching noise when switching from reverse to off so I rewired the fan control wire from 43 to a separate switch,
                                                On my Warco 280VF the VFD is switched on and off via the E stop switch.
                                                I put a diagram in my Album (Not figured out yet how to show it here)
                                                I ditched the change gears for the clough42 ELS project, I can now cut metric / TPI threads at the press of a button or two, and I change turning feed rates on the fly.
                                                YouTube
                                                #455640
                                                Dave Brannigan
                                                  @davebrannigan15528
                                                  The circuit diagram in the manual is fairly representative of what’s actually there but there are errors. The fan connections were something I found to be slightly different. There’s also no filter as described, but I think that refers to the psu for the rpm counter.
                                                  what they really need to do is add a small low voltage psu (there’s actually already one for the rpm display so just make it bigger) and make all the control low voltage. The drive can be reconfigured to take 24v inputs rather than sink it’s own 5v supply signals to ground. Then do away with the contractor and replace it with a small relay as the vfd handles all the high current, this would still not comply with modern machinery safety standards unless the drive had a safe off function but even that is doable. Small low voltage relayed scrub their contacts as the contacts land. Slight sideways movement. Part of the design. Contractors do not. They land square. With higher voltages and currents this isn’t an issue, but with low voltage it is as the contacts do not “clean themselves” during operation. I will be modding mine after warranty.
                                                  I’ll also wire the fans so they only run when the drive does. It’s the only time heat is made inside the box and anything more is just annoying unnecessary noise.
                                                  The lead screw mod is very attractive, but I gotta get past warranty and be sure turning is for me before I do anything radical.
