If my memory serves, and with a look at the Super 7 manual –
If you look closely at the motorising assembly drawing in the manual you will see item 98 Part no A3329 “Abutment Washer” which fits between the clutch body and the Swing Head casting.
The bearing bush in the Swing head protrudes slightly from the casting, such that it lines up with the shoulder on the countershaft when this is inserted. The Abutment washer bears on the shoulder and the end of the bush on one side, and its other side bears on the centre of the Thrust bearing (item 99) in the rotating clutch body, so it is mostly hidden inside the centre boss of the clutch. This prevents the rotating clutch fouling the Swing head. The shoulder toward the left end of the countershaft can be clearly seen in the diagram.
The Abutment washer is 1” ext dia and 5/32” thick, so not a small item. Like most Myford bits it is chemically blackened, which helps it to hide from view!
Myford’s exploded diagrams are wonderfully informative, but their big drawback is that unlike a regular drawing you can’t see where each part belongs unless you’ve dismantled a perfect example.
So the simple answer to the original question is there should be a fat washer in there!
Edited By Robbo on 19/02/2018 23:20:26
