Duncan, I'm considering normal usage on earth. Had it been a space craft use where every fraction of a gram saving on launch costs by getting dead even thread loading, paring away the nut so it flexes nicely to the thread and use of exotic materials etc, then I think your idea is worth considering. No, I'd go further, it would be downright foolish not to consider and implement it.
As it is, at home, I work in
- brass (grade unknown),
- 'steel' (En1a leaded, En8, En16, En24, En54a and occasionally that ubiquitous grade 'Gash' )
- 'ally' (LM4/6, 2017A-T6, 7075-T6511 or 6082-T6),
- silver ('fine' & 'sterling', cleaning up items sintered from 'Precious metal clay' )
- bronze (sintered components from metal clay)
- and plastic (Acrylic, many acrylic alloys of varying colours, stiffnesses & compositions, Acetal. PTFE, Nylon, Tufnol, Polyurethane resins & Polyester).
Just normal 'stuff' to normal 'stuff' tolerances. Nothing to push the boundaries of any technology.
The item I made over the weekend that prompted this thread was a lighter weight cap finial for a Chinese fountain pen. It was made from brass, and I wondered if making it out of aluminium would be better. The pen is a £15 Chinese copy of a £350-500 Parker Duofold Centennial. It is a really good, re-engineered, copy of the Duofold. The only flaws in the Chinese pen are the brass finials at the end of the cap & barrel. I have made 500 odd polyester finials to go at the end of the barrel for people around the world, but was trying a cap finial for the first time. It's rather more highly loaded, so I don't think a polyester moulded one will be adequate.
That is my nearly worn out test pen, showing the effect of severe usage on a 6 year old pen. The old Kaigelu 316 finial is loose, & the aluminium one I made is fitted to the cap. The recess in the aluminium finial can take a sintered bronze metal clay logo if I get around to it.
Richard.
Edited to get rid of involuntary emoticons
Edited By richardandtracy on 08/03/2017 11:21:15
