Posted by David Canham on 20/04/2019 22:19:08:
I then had a proper look at the gearing set up behind the leadscrew drive gear guard and noticed the metric pitch chart pinned to the inside of the guard as the photo. So one question that comes to mind, the gears on the diagram – 60T and 63T plus the 50T and the 45T, are they both one piece items and do they mesh together across via the 63 and 50T.
No doubt Brian will be along shortly, but here is my three penn'orth for the time being:
To deal with the questions you ask one by one:
Firstly you can set up the change wheels any way you like so long as the maths works out and the bits go together, so the set up as per the label you have included is perfectly valid, but does require (obviously) that you not only have those gears identified but also the banjo onto which they are mounted. This is NOT the same banjo as the standard one with fixed centre spacings which is included with the standard quick change gearbox. So your expense factor is obvious.
The gear pairs are splined together by the centre sleeve, which has a key way machined into it. So the 50 and the 45 tooth gears are fixed together and rotate as one assembly, hence giving the ratio change you need. The same is true of the 60 and 63 t gears, they are two separate gears fastened together and rotating as one complete assembly.
What we will call "Brian's" method, as described in detail in his book, has a simpler solution and works just as well as the approximation represented in the gear set Myford drew out in the label you have noticed. However it has several advantages over the "standard" metric kit as you only need a couple of extra gears to do most of the commonly used metric pitches, you don't need a new banjo nor do you need the centre keyway boss. Whole lot of financial happiness there, however the biggest advantage isn't about cost at all, it's that you don't forfeit the fine feed system of the reversible 19/57 gears cluster because you use it as part of the gear assembly. Brian's book has the details.
However you do need a 33 and/or a 34 tooth gear to fit on the first mandrel spindle (below the tumbler gears). Again, Brian;s book describes the details. Now the snag of this is that these two gears are not the easiest of things to find, indeed the 34 tooth one seems to be in national shortage mode at present. But then neither is the metric set, and the special banjo is shades of unicorn poo…
With due deference to the proprieties of advertising on the forum (which is out of order, and I'm not going to do it) I have been making a batch of 34t gears (proceeds to charity) in response to similar questions elsewhere, so if you want one send me a PM and I'll explain further.
And no, I'm not making a profit – I'm not even covering my expenses making them the old fashioned way but if it helps someone try out "Brian's" elegant and simple adaptation, and makes a contribution to charity no-one's the worse for it, so I hope that's Ok with the moderators.
Hope this helps
Simon
