Thiel 158 problem
Thiel 158 problem
Home Forums Manual machine tools Thiel 158 problem
  • #77728
    steamdave
      @steamdave
      Does any reader have a good working knowledge of the Thiel 158 milling machine – or know anyone who does?
      I have lost power feed to the Y axis. There must be a shear pin somewhere that has failed, but where?! I know about the main one on the left hand side of the column and that one is intact.
      Hopefully someone will be able to help.
      The Emerald Isle
      steamdave
        @steamdave
        Y axis power feed failure
        #77731
        Springbok
          @springbok
          Hi
          Try this site
          BUT they do not have a manual for the 158 but it may be a starting point for you
          good luck
          Bob
          #77777
          steamdave
            @steamdave
            Hi Bob
            Thanks for your suggestion. I do have a manual, but it must be based on a later type of machine than mine because there are several differences in it and crucially no shear pin is shown.
            The Emerald Isle
            #77778
            steamdave
              @steamdave
              Hi Rob
              Thanks for your input. I will check on the detent next time I can get to my workshop – I’m away at work now. The Y axis did overrun the normal travel limit, but I don’t remember any problem afterwards with the feed selector not being able to engage. I engaged the selector but there just wasn’t any feed. That is why I wondered about the hidden shear pin.
              The Emerald Isle
              #77906
              steamdave
                @steamdave
                Hi Rob
                Managed to have a look at the milling machine. When I select Y axis power feed, the detent rises and when it is deselected, the detent drops. I have tried to remove the selector lever but looks like I need a puller to get it off – possibly a burr on the shaft, then I can have a look inside the detent mechanism.
                The Emerald Isle
                #77948
                steamdave
                  @steamdave
                  Hi Rob
                  Many thanks indeed for that useful bit of information. Looks like a partial strip down is required!
                  The Emerald Isle
