Hi Graham ,
Aircraft are affected in flight in the same way that weather systems are by what are known as Coriolis forces . An aircraft flying on a nominally straight North South track experiences a force which causes its flight path to become a large radius curve . Pilot usually notes the changes of heading and corrects but simple correction of the heading is not enough and the aircraft continually sideslips at a very slow rate leading to a lateral positioning error after travelling longer distances .
'Systematic drift' as it was then called was known before the war but not really understood . Since long air journeys at that time were usually made in a series of relatively short hops and much of navigation was visually based no-one took much notice .
The coming of faster aircraft , longer non stop flights and more instrument based navigation methods made it nescessary to investigate the effect more properly . When investigated properly everyone was astonished to find how big an error it could introduce .
The effect varies with latitude and with direction of flight – North South flights worst and East West flights least .
On a 300 mile North South flight passing through latitude of UK error is 4 miles . On longer flights errors of up to 20 miles are possible .
The error is mathematically exact and for any given location , heading and speed an optimum correction can be calculated . Neville once showed me his nonogram for doing rapid corrections in flight .
The coming of much better electronic navigation aids from the sixties onwards made all the above academic since most modern systems give actual ground position and true heading and true speed . Any Coriolis force effect is now just lost in the almost continual small course heading corrections of modern flying .
Regards ,
Michael Williams .
PS : Neville never actually told me the reason but most of his fight navigation trials in very adverse conditions and his researches into dead reckoning navigation were taking place during the worst part of the Cold War – draw your own conclusions .
Edited By MICHAEL WILLIAMS on 23/10/2012 15:50:22
