PLEASE SEE COMMENTS BELOW THE 'BLUE BOOK' HAS BEEN SUPERCEDED!
The standard limit for not having a certificate is 3 bar-litres. One bar is 14.5 psi, so you can have a small boiler running at reasonable pressure without needing a test certificate (unless that's a special requirement of an organiser/host).
I am not sure this has ever been clearly explained in ME, but ironically our sister publication Model Boats has an excellent explanation here:
Bear in mind that boat boilers tend to be smaller and lower working pressure, so as he says some 90% of boat boilers are below the limit. The same isn't true of most model locos, but it does apply to many boilers for stationery engines, small traction engines and smaller gauge locos.
Example: my centre-flue boiler is 8cm diameter with a 2.5cm flue and 14 cm high (reason for using cm will become obvious). The cross section is 50 cm2 – 5 cm2 = 45 cm2, so that's volume (including steam space) of 630 cm3 or 0.63 litres. Lets say 0.65 litres to allow for the half-dozen small-bore cross tubes.
The working pressure is 30 psi or 2.1 bar, so the capacity in bar litres is 1.37. I could happily run it at 60 psi (it's designed to work at such a pressure, but there would be no point), or it could have been 4"/10 cm in diameter.
The test I applied to the safety valve of the (gas fired) boiler was to set the safety valve and turn the gas as high as it would go (any higher and the flame blew itself out). The safety valve passed all the steam the boiler could make without the pressure rising significantly (the official test says no more than 10%).
I can't say that any club or exhibition would allow me to steam the boiler on that basis, but it would be 'blue book' compliant and it should be possible to insure it without a test. I've seen a Tich boiler estimated at about 0.45 litres volume, but I'm not sure if any club would let one run without a pressure test.
Hope that helps.
Edited By Neil Wyatt on 17/06/2014 18:07:38
