Not sure what has happened above as some of my post is hidden by the adverts on the RH side. Perhaps a Mod could delete the post please. Here it is again:
For what its worth I contacted the company (Roxon in Gloucester) that installed our solar panels about a battery system, I had asked about batteries when they did the original fitting maybe six years ago [edit to add installed in 2013!] and they said it wasn't worth it for my usage. I asked again recently and this was their response:
"It’s an interesting question and one Roxon is being asked more and more.
The following is a reply that was sent this morning to another customer and the same principles will apply to you, namely that the electricity you get from your battery will probably cost more than buying from the grid, even though it was yours to begin with. At best it might save you a few pence per unit but you’ll have spent £3-4,000 for the privilege.
"The software predicts that adding a battery would increase your rate of self consumption from the PV from about 55% to 75%.
About 7.5% of the DC output is lost in the battery charge / discharge process so your additional energy would be equivalent to an extra 1,250kWh per year, worth about £395 at the typical present tariff of 30p/kwh plus VAT.
There are other ways of adding value to a battery of course, like off peak charging but I can’t calculate the benefit. Also, potentially, protection from power cuts, so I’d be happy to quote for a battery solution if of interest."
I have had discussions with Dave (Samsaranda) about his set up and it seems that you need to be on one of the economy tariffs and have a high electricity usage to really make it work.
