Taper sleeve adapter
Home Forums General Questions Taper sleeve adapter
Viewing 10 posts - 26 through 35 (of 35 total)
  • #507621
    Me.
      @me1
      Thanks – exactly the info I needed – home workshop grade it will be.
      Me.
        @me1
        I have just realised I was looking at the solution to my problem all along – I already have one taper tool that fits in my spindle. I can make that into the adapter sleeve – it looks like it was a tool to take a Jacobs Chuck so I can machine away all the business end and all I will need to do is turn the internal taper on the old tool….. simples…. I hope.
        #508008
        old mart
          @oldmart
          Thats the ticket, always get the job done the simplist way, just be sure the donor will not be missed at a later date.
          #525284
          john raynham
            @johnraynham96810
            6.2.21 Model Engineer.168912 Forum.Here I am again. Yes its the Adcock Mill nitemare Cannot say I have got anywhere regarding this Adcock Mk1 Horiz/Vert mill of mine. I was a fool to buy a pile of parts stored in a shed Months later finding out the top arm was missing and the tapers did not match anything I had prev encountered Started to try to overcome the issues but found for instance that top arms are ground not turned and the tapers are NS. Since then serious illness, no med help, and property faults which were covered up by teachers sellers has pout me into a hole. The machine stands outside covered by a tarp. I don't even have any machine wkg apart from hand drills and so on. Today I found the article about a sleeve to overcome some of the issues. I found them very interesting. Am thinking of attempting the get rid of this machine as I gave failed. Am hoping to get money back as its got a vertical head which must be worth money. What a shame all this failure is. Difficult to cope with sometimes particularly when wearther is bad. Never did like failure.
            #525288
            Steviegtr
              @steviegtr
              Posted by john raynham on 06/02/2021 16:10:35:
              Don't beat yourself up John. Plenty of us will have bought something duff in our lifetimes. Like you say, sell it & move on. Regards.
              Steve.
              #525293
              IanT
                @iant
                Good advice John, if it's causing you grief – just sell it and don't worry about it.
                It will probably be a weight off your mind.
                IanT
                #525326
                john raynham
                  @johnraynham96810
                  6.2.21 Grateful to IAN. Best regards
                  #525329
                  john raynham
                    @johnraynham96810
                    6.2.21 Grateful to stevie GTR . Will try to reform.
                    #525334
                    Me.
                      @me1
                      Buy a BT40 to BT30 adapter from ARC. Take time on a Lathe to machine it down to the right taper and job done – I did mine that way.
                      Adcock back in use – Give it a go, you'll be surprised.
                      #525432
                      Howard Lewis
                        @howardlewis46836
                        FWIW
                        When I needed to make male and female tapers that matched, having set over the Top Slide, I turned and bored the tapers without disturbing the setting.
                        Having had an open ended 2 – 3 MT sleeve stuck in the Mill (With a drawbar hole too small in diameter to be able to use a brass drift ) I made up a crude puller with a split end that could be pushed through the sleeve, and then expanded by pulling a taper into it. The rim of the split "top hat" piece then sat on the end of the sleeve and tightening a 1/4 BSF (Could be M6 ) nut pulled the sleeve free. Has worked every time when needed.
