Tailstock capstan head
Home › Forums › Workshop Tools and Tooling › Tailstock capstan head
  • #18091
    Rod Ashton
      @rodashton53132
      Maintenance
      #238010
      Rod Ashton
        @rodashton53132
        I have acquired a well used tailstock capstan head. The normal six position rotor, locked by a sprung dowel for radial locking. Locking is the point. I waggles like the proverbial. Wondered if anyone has refurbished one. As I may as well bin it, for all the use this one is currently.
        #238017
        Emgee
          @emgee
          Hi Rod
          If you dimantle the unit the places that are worn will be obvious, they may be on the pin or socket/s, no doubt a bit of both. If just the pin is worn you only need make another to a size that suits, if the sockets are worn then perhaps you can machine them to a consistent size and make the pin to fit. Rather than make a complete new pin you may be able to turn the end down for a short length then add a sleeve with loctite, turn that to suit the socket diameter.
          Emgee
          #238055
          Rod Ashton
            @rodashton53132
            Emgee – Thanks, my distain has diminished and having stripped it I can see that it needs needs reaming through and a new pin as you suggest. I think if hold each station in a headstock collet I can align from collet to tailstock and hand ream.
            #238058
            Ajohnw
              @ajohnw51620
              I have one on my Boxford. I also have the original tailstock quill. More effort is needed to drill large holes but they have a lot more feel so I have never been tempted to revert to the original.
              I'd assume that the parts all came from the same source and mine does have a very slight problem. Over the years the wide end of the morse taper has spread a little meaning I had to sand the outer diameter of the quill at the end a touch. This suggests that the morse taper was very slightly off. As it's easy to cure a minor point really. It grips really well but in it's original form things might not be so good in that respect. Hard to say. The main reason morse tapers use such shallow angles is that it does offer some tolerance.
