Posted by not done it yet on 05/07/2018 22:59:49:
I was intrigued by the shaper with grinder attached, but although I PM’ed the member, I didn’t receive a reply.
Anyone comment on that possibility? Might be good for a surface finish, but not for really accurate metal removal? Maybe a poor man’s option? A waste of a good shaper? Anyone else tried it?
I used my shaper with an angle grinder attached to clean up the weld repairs to a drill press table when I was somewhat younger. I wouldn't do it again… Got the job done, but I can't help feeling that the grit caused wear on the ram and its ways.
A few years later, when I was designing my shed, I asked to buy a scrap Herbert Junior surface grinder from work that I knew was headed to the skip. Some months later, I got an invoice for £75+VAT = £86.25 for a Jones & Shipman 1400. I re-designed the shed around it!
It's seen a fair bit of use in the re-building of the Hardinge HLV and the Beaver VBRP Mk1.
It also gets used for grinding lathe tools, especially threading tools.
After I've re-lapped the surface table to an acceptable flatness, it'll finally get re-built itself. It's 42 years old and has got 3 tenths of wear in the table ways. That's perfectly ok when roughing cast iron down to the point where it's a simple job to scrape it flat, but it's annoying when aiming for finished dimensions on hardened pieces.
A surface grinder is not at all necessary for the vast majority of workshops. But if you get a chance at one for a good price and have the space for it, you'll enjoy having it.
