Suitable varnish for MS
Home › Forums › General Questions › Suitable varnish for MS
  • #249620
    Eric Cox
      @ericcox50497
      Can anyone suggest a suitable clear varnish for polished Mild Steel to stop it rusting.
      #24673
      Eric Cox
        @ericcox50497
        #249623
        Roger Head
          @rogerhead16992
          Someone (can't remember who) has previously recommended Rustins metal lacquer.
          http://www.rustins.eu/Details.asp?ProductID=811
          Roger
          Edit: Note that they (Rustins) recommend it for brass, copper, bronze, and silver, with no mention of MS at all. It would be interesting to know why MS is omitted. Maybe they simply expect any steel product to have a protective coating already applied.
          Edited By Roger Head on 06/08/2016 10:19:12
          #249624
          Ian S C
            @iansc
            If the thing you want to protect is going to sit on a shelf, use hair spray.
            Ian S C
            #249628
            Brian Wood
              @brianwood45127
              Eric,
              I have used the lacquer from Rustins on all manner of jobs which must have included mild steel, without apparent ill effects. For small items, dipping works well to leave a nice smooth blemish free surface.
              #249629
              Roger Head
                @rogerhead16992
                Posted by Ian S C on 06/08/2016 10:14:13:
                If the thing you want to protect is going to sit on a shelf, …
                But if not, then here's a good Aussie product
                http://www.kbs-coatings.com.au/diamond-finish-clearcoat-instructions/
                Note that you need to warm it up a bit for curing.
                Usual disclaimer…
                Roger
                Edited By Roger Head on 06/08/2016 10:45:57
                #249687
                John Reese
                  @johnreese12848
                  Clickspring uses a 50-50 dilution of clear lacquer for his polished metal parts.
                  #249688
                  roy entwistle
                    @royentwistle24699
                    Diluted with what ?
                    #249703
                    john carruthers
                      @johncarruthers46255
                      Diluted with what ?<<
                      I use acetone 50/50 with Rustins, not too thick a coat, dries fast and lasts well.
                      #249711
                      Alan Wood 4
                        @alanwood4
                        Linseed oil cut with thinners,
                        #249716
                        speelwerk
                          @speelwerk
                          I now use old fashion French polish for metal parts, works easy and dries fast. Niko.
                          #249736
                          mechman48
                            @mechman48
                            + 1 for Ian SC… hair lacquer.
                            George.
                            #249821
                            I.M. OUTAHERE
                              @i-m-outahere
                              Although i haven't tried it , what about clear nail polish thinned with acetone ?
                              What about 2 pak clear Automotive paint ?
                              I would never have thought of hair spray !
                              Ian.
                              #249829
                              Jon Gibbs
                                @jongibbs59756
                                Melamine pre-catalyzed lacquer is crystal clear – comes as liquid or spray can.
                                You can thin the liquid with cellulose thinners and paint on.
                                Jon
