Static Steam Engine.
Home › Forums › Miscellaneous models › Static Steam Engine.
  • #4190
    DAVID HOWORTH
      @davidhoworth40264
      #78807
      DAVID HOWORTH
        @davidhoworth40264
        Dear Members,let me first of all appologise if my query has been posted in the wrong section.
        My question to you all, is,from the attached photographs is anyone able to tell me who manufactured the kit,as it does seem to have been built using a kit of parts,and does it have name etc.etc.
        http://s1178.photobucket.com/albums/x375/TSDAVE1/
        Any information would be very much appreciated,as I am in the process of completely refurbishing the engine.
        Rgards,
        Dave.
        #78808
        wheeltapper
          @wheeltapper
          Sorry Dave, can’t see the pics, says its a private album.
          Roy
          #78809
          DAVID HOWORTH
            @davidhoworth40264
            Sorry wheeltapper,I have now made the link public,could you please let me know if you can now access the photographs.
            Regards, Dave.
            #78810
            NJH
              @njh
              Hi Dave
              It bears many similarities to the Stuart S50 but how big is it?
              Norman
              PS can access photos but then cannot get back!
              Edited By NJH on 28/11/2011 18:59:15
              #78812
              DAVID HOWORTH
                @davidhoworth40264
                Dear NJH, I must admit it does look similar to the Stuart S50,but not quite as I see it,maybe wrong though.
                The baseplate casting is 285mm.x110mm. o/a.
                Regards, Dave.
                #78813
                DAVID HOWORTH
                  @davidhoworth40264
                  Should have said NJH, that the base casting is a seperate casting to the main shaft carrier bearings and piston guide/slide mechanism.
                  Regards, Dave.
                  #78817
                  maurice bennie
                    @mauricebennie99556
                    #78818
                    maurice bennie
                      @mauricebennie99556
                      Hi Dave. I have this engine ,its a STUART MILL ENGINE about 10″ long .Would post a pic but dont know how , one day perhaps.
                      Maurice .
                      #78820
                      DAVID HOWORTH
                        @davidhoworth40264
                        Hi Maurice, are you sure, as the baseplate on the engine I have is 11 1/4″ in length and 4 1/4″ wide.
                        Do you know if the engine you have in mind is shown in the latest Stuart catalogue as I can’t find it in the one I have, but addmittedly it is 3 years old.
                        Thanks for your thoughts on the subject Maurice.
                        Regards, Dave.
                        #78824
                        maurice bennie
                          @mauricebennie99556
                          HI David. Measurements base plate =220x(60 down to50) sort of L shape. fly wheel 95×20 with 6 spokes cylinder45x25. This engine I built about fifty years ago .OUCH.
                          Yours is bigger than mine but looks the same .sorry about the MM .
                          Best wishes MAURICE.
                          #78827
                          maurice bennie
                            @mauricebennie99556
                            HI again Dave. Have just found the plans of the engine .
                            STUART TURNER Ltd HENLEY ON THAMES ALT.NO.72 DATE 6,10. 80 DRG.NO.90092 DRAWN by R.G.Pender DATE 24.8.77 .And as said before it is an. S50 MILL ENGINE
                            Hope this helps , Maurice .
                            #78829
                            DAVID HOWORTH
                              @davidhoworth40264
                              Hi Maurice, thank you for your further information,and being as I have stripped the engine down completely since I took the photo’s,I have reffered to your sizes and give you the sizes of my engine.
                              Flywheel – 128mm. dia.x27mm. face with 6 spokes.
                              Piston diameter – 32mm. with a 38mm.stroke.
                              Still not convinced that it is a Stuart,but I do respect your views,and by the way I am 70 years old at the end of next week,also “ouch”.
                              Regards, Dave.
                              #78830
                              DAVID HOWORTH
                                @davidhoworth40264
                                Hi Maurice,me again,with half an appology,as I have just seen the engine like the one you must be talking about, for sale on Ebay,a Stuart Turner S50.
                                Again quite a bit smaller than mine,but probably the same size that you built,and the layout is very similar if not identical.
                                How odd therefore that the engine I have is so much larger.
                                Best regards, Dave.
                                #78842
                                Rob keeves
                                  @robkeeves73950
                                  Didnt Clarkson produce castings for a mill engine about that size, i may be wong but im sure i have seen one.
                                  Regards Rob.
                                  #78849
                                  DAVID HOWORTH
                                    @davidhoworth40264
                                    Hi to all who have replied to my thread,and thanks for your time and inputs.
                                    The observation that I have to make, considering my and members general thoughts is that the engine I have is some sort of “blown up” S50, manufactured by a company other than Stuart.
                                    I would still appreciate thoughts from members who have yet to read my thread,as I am more and more intrigued now than before.
                                    Regards, Dave.
                                    #78891
                                    DAVID HOWORTH
                                      @davidhoworth40264
                                      Any more thoughts on what engine I appear to have in my workshop,”please”.
                                      Best regards,
                                      Dave.
                                    Home › Forums › Miscellaneous models › Topics
