Thats the official way of cutting non-native threads on a Smart & Brown 1024 VSL. Albeit via the big red button rather than a foot bar. So nowt wrong with the principle unless serious engineering cock-up has been made so the brake engages before the motor drive drops. On my 1024 there is a very short, but distinct, pause after the motor power is cut before the brake hits. About 1/2 turn of the chuck at the 55 (ish) rpm I was using to do 14 tip on my metric 1024 yesterday.
Motor may be a bigger issue. Single phase ones don't like too many starts in quick succession as the starter winding doesn't get a chance to cool down and can eventually overheat. Even high quality ones tend to be specified for around 10 or less starts per hour. In practice how bad too many starts is probably depends on loading. I guess the book refers to the motor being used at its rated start load capacity so the starter winding would be working hard. Lathe spins up under pretty light load viz:- chuck, work, drive and gearbox innards. Not insignificant but nothing like full motor capacity.
This is the one time where VFD driven three phase motor is not an advantage as you need a finite time to spool down the motor unless you want to trespass on the overload safety margin by simply dropping the input contactor out. Can be OK if you have a decently oversize VFD with a inherently good overload capability, like the Whole Shop set-ups Drives Direct sell, but pretty much a no-no for a matched VFD & motor combination.
Clutch is nicer. I keep wondering if there is a way to get one on my 1024.
Clive.
