Stalling Lathe
Stalling Lathe
Home › Forums › Workshop Tools and Tooling › Stalling Lathe
Viewing 3 posts - 26 through 28 (of 28 total)
  • #286006
    Hopper
      @hopper
      Glad you got a good result in the end. My old man used to hammer into us "Check the simple stuff first" when we were ready to strip a motorbike engine down to the crankpin because a loose tappet was rattling. He was right too, as usual!
      You might put a dab of white paint or similar on that pulley, and the countershaft pulley, for future reference so you can see at a glance in the gloom if it is turning or not.
      Edited By Hopper on 25/02/2017 23:21:40
      #286278
      Harry Wilkes
        @harrywilkes58467
        HPosted by Hopper on 25/02/2017 23:19:01:
        "Check the simple stuff first"​ too right I once had an electrician work for me 'briefly' he told me the hoist motor on a crane needed to be change, so I decided to go check it out myself which I did a found tow of the three motor fuses blown due to a damaged catenary cable nothing wrong with the motor thankfully !
        #286313
        mark costello 1
          @markcostello1
          Another OLD adage is, "If You don't know what is wrong with something, fix what You know needs fixed,You might find the problem along the way."
