Square section silver steel
Home › Forums › General Questions › Square section silver steel
  • #25035
    Mike Crossfield
      @mikecrossfield92481
      Source of 1/16 inch square silver steel sought
      #279940
      Mike Crossfield
        I need a short length of 1/16 inch square silver steel for a clock project. Tried all my usual sources without success. Anyone know where to get some?
        #279942
        MW
          @mw27036
          Mike, I think this is hard to find, I only know of round.
          You might want to try gauge plate as this ground flat, high carbon, harden-able stock.
          Michael W
          Edited By Michael-w on 24/01/2017 18:07:44
          #279949
          John Haine
            @johnhaine32865
            MSC Industrial do 1/8th but not 1/16.
            link
            You might have to buy 1/16 gauge plate, saw out a length, and file/mill to size.
            #279962
            Roy M
              @roym
              Mike, you can get 1/16" square key steel, this is really tough,but not sure of the hardening process. It's normally nominal size plus. RoyM
              #279963
              pgk pgk
                @pgkpgk17461
                Mo idea on price but ask these guys: **LINK**
                #279966
                David George 1
                  @davidgeorge1
                  Hi Mike
                  What is it for and do you it need to heat treat it. If you don't live to far from (Nottinghamshire) me I have some 1/16 by 2" wide gauge plate which is the equivalent spec to silver steel and what length do you need. Send me a message if any good.
                  David
                  #279969
                  Bizibilder
                    @bizibilder
                    College engineering stock some square but unfortunately not as small as 1/16 http://www.collegeengineering.co.uk/product/imperial-13-long/ Might be worth a phone call to see if they know a supplier.
                    #279971
                    Richard S2
                      @richards2
                      Check These people out- **LINK** based in the Midlands judging by the area phone code.
                      #279985
                      Mike Crossfield
                        Thanks for all the replies. It looks like I!'s probably not available. At least not in the very small quantity I need at a sensible price. I need it for a maintaining spring in a clock barrel. What matters is stiffness after hardening. Doing some sums just now it looks as though a round section would need to be about 20% greater in diameter than the side dimension of a square bar for the same stiffness. So substituting a round bar for the 1/16 square bar would means I would need a round bar 0.075 diameter. This is pretty close to 2mm, which is readily available size. So I'll go with that.
                        #279989
                        julian atkins
                          @julianatkins58923
                          Hi Mike,
                          I have plenty of 1/8" square silver steel. I cant see me needing much of it for any future projects.
                          I can send you whatever length you need.
                          You can then mill or file it down to size.
                          PM me if you want some.
                          Cheers,
                          Julian
                          #280196
                          John Reese
                            @johnreese12848
                            Does McMaster Carr serve the UK? They have it in keystock, W1 tool steel, 1095 spring temper, Stainless, and more.
                            #280201
                            Speedy Builder5
                              @speedybuilder5
                              Why not file down a bit of round rod to suit ?
                              #280217
                                Posted by Speedy Builder5 on 26/01/2017 07:01:19:
                                +1 for that
                                The filing of squares is a very useful horological skill.
                                Here: on a reduced scale, I supect, is a good demonstration **LINK**
                                How to File a Square on a Cylinder
                                Relevance will of course depend on your interpretation of 'a short length'
                                Edited By Michael Gilligan on 26/01/2017 08:39:58
                                #280229
                                  I think I may have a bit of 1/16 SS – I'll be able to check later, what length do you need ? is it for pallets?
                                  Mike Crossfield
                                    Neil,
                                    It's a spring for a Harrison maintaining mechanism on the barrel of a long case clock. I need a piece about 90 mm long.
