Hi cva-glen ,
are you running a job with the old cams now?
the cams for the CVA and BSA automatic screw machines are made from 3/8″
plate if I remember correctly with a 1″ hole for the spindle
original cam blanks are divided into 100
BSA still manufacture the cams,It could be an answer If you can not find CVA ones
but you can make your own from 3/8″ plate
BSA and I assume CVA manuals give you examples of how to mark out the cams your self
its hard work ,I know but I’ve done it once for my dad about 40 years ago
he started as an autosetter in the 40’s at the BICC factory in Prescot ,but unfortunately
is no longer with us to ask
If your cams are still usable you could just make copys but compensating for the ware
you could try cnczone :-
