Hi. I need to bolt on a 25mm square bar to the side of something. An M6 stud protrudes from a surface and that will go through a hole made in the square tube. But, I have a small problem: The stud is rather short, it does not protude beyond the surface of the tube, so I cannot use a regular nut on the stud.
I need something like a thumb screw, which will recess into the tube and make contact with the stud. The length of the shank of the thumb screw needs to be 25mm or so. I've not yet found a suitable thumb screw. If not a thumb screw I need something very similar, perhaps with an hexagonal head. Do such things exist? Things like thumb screws, but with hexagonal heads? Thanks. Rich
