Sir William
Sir William
Home › Forums › General Questions › Sir William
  • #21943
    Peter Wood 5
      @peterwood5
      Milling Steam Chest Ports
      #75669
      Peter Wood 5
        @peterwood5
        II
        #75670
        Peter Wood 5
          @peterwood5
          I have just started on this project and having milled the steam chest from the integral cylinder casting I now have to mill the 2mm and 3mm steam inlet and outlets ports. My problem is that the steam chest is 11mm deep and the ports have to be milled a further 6mm deeper. My 2mm end mills only extend about 12 mm from the chuck and I have not found any long reach 2mm end mills .
          Can I put a spacer in the screw thread of my collet chuck to extend the reach of the 2mm mill or could I get away with putting the mill in a normal drill chuck??
          #75672
          Gray62
            @gray62
            If you are using a Clarkson type collet chuck, then NO, you cannot use a spacer. The collets in these chucks do not grip the cutter tighlty, their function is to provide accurate alignment. The cutter must be in firm contact with the taper at the rear of the chuck in order to lock the cutter in place.
            Drill chucks are not designed for the forces placed on them by the action of milling, in addition, milling cutters are invariably hardened throughout, therefore a dril chuck will not be able to grip them adequately to prevent rotation/displacement of the cutter, in addition, you are likely to damage the chuck jaws.
            Long series endmills and slotmills are available, try Tracey tools they have sets advertised on their website and will probably be able to supply individual cutters as well
            regards
            Graeme
            #75696
            Peter Wood 5
              @peterwood5
              Thanks Graeme for the definitive answer. I will give Tracy Tools a call tomorrow.
              Peter
              #75742
              Peter Wood 5
                @peterwood5
                Well Tracy Tools don’t have long series 2mm or 3mm slot drills and I have drawn a blank on the internet. Does anyone know a source?
                This may sound a daft question, but why are the inlet and outlet ports from the steam chest shown as slots when they connect to just two steam passages to the top and bottom of the cylinder. Would two drilled holes at each end of the slot locations, connecting with the longitudinal steam passages work just as well?
                Any ideas?
                Peter
                #75744
                Keith Long
                  @keithlong89920
                  Putting in “long series slot drills” as a search term in Google turned up pages of potential suppliers. Tracy Tools have them listed but no details of stock but Cromwell Tools and Chronos come up as possibles as well.
                  Keith
                  #75772
                  Peter Wood 5
                    @peterwood5
                    Thanks Keith. However I have tried all of them and none stock 2mm LS.
                    I can get 3mm from Chronos which will do the exhaust port.
                    For the present I have settled for 2 and 3mm drilled holes instead of the design slots.
                    Perhaps Anthony Mount will provide the answer when he gets around to the cylinders in the ME construction series.
                    Peter
                    #75775
                    Roger Banks
                      @rogerbanks33631
                      Peter,
                      Try Cutwel Tools.
                      They sell long series end mills and slot drills with Weldon shanks. I’m not sure if they sell screwed shanks.
                      Roger
                      #75781
                      David Littlewood
                        @davidlittlewood51847
                        Peter,
                        As Graeme said, drill chucks are quite unsuitable for holding milling cutters. however, ER series collets are quite suitable – I frequently use them for this. You should find this gives you a little extra reach with a standard length slot drill.
                        However, if that does not give you enough reach, you can get long series slot drills from J&L/MSC:
                        Their prices are not the cheapest, but their speed of delivery is amazing. Also, look in their monthly sales flyer, you can often get what you need at a significant discount.
                        David
                        #75796
                        Peter Wood 5
                          @peterwood5
                          Thanks for all the suggestions.
                          I have located LS 2mm & 3mm screw shank slot drills but at outrageously expensive prices – like £34 for one off each after P&P and VAT. Surprisingly Weldon shank can be obtained much cheaper.
                          I am now thinking that a cheap 6mm MT3 end mill holder from Arceurotrade and Weldon type slot drills might be the answer. Still expensive for six small slots.
                          Hey ho – you can’t take it with you!
                          Peter
                          #75813
                          David Littlewood
                            The J&L price for 2mm long series slot drills (with screw shank) is £10.55 + VAT and postage. Page 233 of the catalogue.
                            David
                            #75815
                              Can’t you drill a bit of 1/2″ or 5/8″ rod 6mm and tap it for a grub screw then use one of the little FC-3 cutters in that, hold the whole thing in a milling chuck or even a MT collet.
                              Think thats what I used on my Fowler, valve chest is 11/16″ deep and then used an 1/8″ cutter on the ports
                              J
                              Edited By JasonB on 04/10/2011 18:26:01
                              Edited By JasonB on 04/10/2011 18:31:17
                              #75836
                              Peter Wood 5
                                @peterwood5
                                David
                                I don’t want to appear ungrateful for your help but I just checked the J&L prices again.
                                2mm LS £10.55 3mm LS £11.93 Sub total £22.48
                                Shipping £4.95 (the cheapest option)
                                SalesTax £5.49
                                TOTAL £32.92
                                Hence my observation that it was expensive.
                                Peter
                                #75838
                                David Littlewood
                                  Peter,
                                  Like I said, look in the October monthly sales flyer for the best deals. 2 and 3 mm long-series slot drills (not screwed shank in this case) at £2.35 each:
                                  …and anyone who can’t find some other things to make the postage worthwhile has a *lot* more willpower than I do!
                                  David
                                  #75845
                                  Dusty
                                    @dusty
                                    Remember Peter, it’s not your money you are spending ‘it’s your kids inheritance’
                                    #75860
                                    Peter Wood 5
                                      @peterwood5
                                      Well I solved the problem though I suspect some may not approve of my method!
                                      I cut the threaded end off a broken mill which had a 6mm shank. After grinding the cut end flat I cut a slot in it to take a screwdriver. The ‘grub screw’was then fitted in the Posilok chuck collet adjusting it with the screwdriver until it was slightly proud of the screw hole. The slot drill was then inserted into the collet and the chuck tightened, firmly gripping the slot drill well enough to prevent any slippage. The reach was now extended by about 10mm
                                      The method worked well enough to accurately mill the slots.
                                      I cannot claim any credit as the method was suggested to me by a friend who had been an instrument maker for many years.
                                      However thanks for all the suggestions and for the many new tool suppliers in my bookmarks.
                                      Peter
                                      #75970
                                      Sub Mandrel
                                        @submandrel
                                        Until I came to the last message I was going to suggest making a 2mm cutter on the end of a length of silver steel. I’m sure such a simple arranegment would work fine for cutting a small slot in good quality cast iron.
