Several people have reported problems with corrosion as a result of using silicone sealant in small Stirling cycle engines.
The common RTV silicones do use acetic acid as part of their curing method.
This has been a problem in electronics assys for some time, with the acid corroding conductors and leadwires, and as a result the silicone companies developed "neutral cure" or "electronics grade" RTV sealant with no acetic acid cure.
I am not sure about availability in the UK but in North America it was marketed as Dow 737 neutral cure RTV sealant.
Maybe Radio Spares or Farnells carry it in UK. Digikey and Sayal Electronics both carry it in USA and Canada.
Good luck JD
