An under advertised bit of infomation gleaned off the web is is that if you're using carbide, you really SHOULD be climb milling~ as not good for tool life otherwise.
I'm not saying i know very much, but i read up what i can, & like to experiment.
General advice seems to be not to climb mill on most manual machines except for "finishing cuts" ~ as it can be potentially very dangerous when the backlash kicks in & something grabs.
Well thinks I, My X1's roughing cuts are probably most peoples idea of a finishing cut, so i tried it & now i
almost always climb mill on my little x1.!! 10mmx1mm cut in BMS is ok climb milling for me.
Some pro's on climb milling~ kinder on tool (read~ less wear), less horsepower needed for given cut & to my ears a sweeter cutting noise.
You must make sure all gibs etc are snug~ i've fitted thrust bearings to leadscrews & this is a good starting point if you wish to try climb milling.
Bear in mind your x2's a more powerful beast than mine so more likely to come to grief.~ start lightly & build up to a "safe" level of cut.
I did get a "grab" early on in experiments(before thrust bearings fitted) , whole table lurched,terrible noise, motor stalled & i thought i'd bust something for sure,
It then cut very badly afterwards,but luckily all that was needed was re adjustment of gibs,leadsrew nuts etc. Not happened since. But on a more powerful machine i may have been dodging flying metal !
Please read up about climb milling first if you've not already done this so you understand the potential dangers on a manual machine.
All i can say is it works for me & my x1. hope that helps a little.
