I have searched the forum and it is obvious there are people with knowledge on this topic but none of the old posts covers the point I want to raise.
I have an early (1948) ML7 with history unknown which seems to have very little wear and no damage, I have been using it for a few projects over the last 5 years but recently realised the headstock bearing caps screws were loose. I loosely tightened the caps and the spindle locked up.
I removed the caps, pulled out the spindle and found both spindle and bearing were in 'as new' condition. I measured the shims, they were the laminated type, all to be 17thou .
Thinking someone had removed too many laminates I ordered new shim packs from Myford and were surprised to find that the new ones were also 17thou. I then replaced the bearing caps without spindle and shims and tightened the caps until the white metal bearing halves were touching each other and measured the gap where the shims would be, it was 16 thou. So even with new shim packs I was only going to 'space' the bearing by 1 thou at the most?
The bearing caps showed no evidence of filing of any post manufacture machining so what’s happening?
I think at some time in the recent past it was fitted with new spindle, shim packs and white metal bearings (before they became unavailable) and the last owner found the spindle locked without any of the shims being torn off so he simply left the screws loose.
Anyone else had this problem, the only solution I can see is to just add the new shims on top of the existing then rip off until correct adjustment.
– Alan
