Posted by Martin Connelly on 18/02/2017 19:33:11:
MalcB, weight is mass times gravity so if the mass is scaling up by a factor of eight when linear scale is doubled then weight will also go up by a factor of eight unless gravity changes.
Martin
Hi Martin,
Agree mass x specific gravity = weight.
So lets do an exagerated example of two materials I can remember the specific gravities of:
2 cu inches of steel ( 0.27lbs/cu in ) and 2 cu inches of lead ( 0.36 lbs/cu in ).
This equals 0.54lbs and 0.72 lbs = 0.18lbs difference
Scaled by factor of 8 = 4.32lbs steel and 5.76lbs lead = 1.44lbs difference.
Therefore the difference does scale up by eight.
So unless i have missed something, yes i think i agree with whats being said.
